FREE ENERGY USING MAGNETS
Started by nightlife, May 13, 2008, 11:27:44 AM
gotoluc
Quote from: scotty1 on May 16, 2008, 08:42:01 AM
Here is a test for those who are curious.
Place a 1/8" dia and 18" long bare copper wire in an E/W direction.
Place a car battery South of the wire...pos terminal East, neg terminal West.
Use a lead to connect the pos to the East end of the wire...
Connect another lead to the West end of the copper wire...leave the neg terminal open for now.
Place a 1" long very thin needle on top and accross the copper wire so it points N/S.
Place another identical needle under the copper wire also in a N/S direction.
Hold both needles on the copper wire with your fingers.
Connect the lead to the neg terminal for a short time until the copper wire warms up.
Keep the needles the way they are facing and first hang the top needle by its center in the Earth's field and you will see that it stays the way it is....
Now take the needle from under the copper wire and hang it by its middle in the Earth's field.
THIS TIME THE NEEDLE WILL TURN AROUND 180 DEGREES.
Scotty.
Hi Scotty,
great work you have done ;D  thanks for sharing and mostly with all your great videos. I would like to do your experiment above but could you do a video of it?  it is kind of difficult to follow written :-[ I'm more of a visual guy.
Thanks
Luc
gotoluc
Quote from: nightlife on May 16, 2008, 10:08:01 AM
Thanks to a private message I received from rukiddingme, I realized that we do not even need power to create power.
One of my first designs was a magnet motor that was to use three to pass one. I had no luck doing so and I abandon that design. I have recently came up with the understanding that the air gap between to polarity's are strong enough to pull a magnet through one polarity. Therefore we can use two to one and create what most call over unity. This can be done.
WE NOW HAVE A POWER SOURCE WITHOUT THE USE OF POWER AND IT WILL LAST AS LONG AS THE MAGNETS LAST.
Hi Tom, I think I now understand your design ideal. Also it seems you have received a confirmation that it is the correct approach. Please keep us informed.
Thanks
Luc
gyulasun
Hi Thomas,
Sorry but you lost me...  I would like to understand, can I?
Thanks,  Gyula
nightlife
gyulasun,
QuoteSorry but you lost me...  I would like to understand, can I?
I am sorry but I have yet to post that design but I should be done building the proto type for it tonight. I have always had the design and I was just missing one key feature that I have just figured out after I stated this thread.
I will be posting more later.
Dact
Quote from: scotty1 on May 16, 2008, 05:37:11 AM
Hey...I made a motor like the drawings here way back in 2005...hehehe
Here you can see it going...
http://www.youtube.com/watch?v=Pj6gaf4chzM
Now about the amount of energy in one end of a coil core.....IT IS ONLY 25% OR LESS OF THE INPUT POWER.
Maybe you are suprised by that, but it is true......one pole of the coil core shows only 25% or less of the energy that went in the coil from the battery.
Most coils are wasting the other 75%.... ;D
Here is another motor i made that drives my Wimhurst machine...It works a similar way, but uses repulsion at first.....then the flux from the drive magnets goes into attraction by itself, and then just short of alignment the electromagnet changes its flux to again repel the incoming drive magnet.
http://www.youtube.com/watch?v=OqXtWeAQx60&feature=related
To see Lenz's law acting on the coil watch part 2....
YouTube claims these are no longer available. True?
scotty
"Terror hearts out, always;
Terror fabric, NEVER!"
