FREE ENERGY USING MAGNETS
Started by nightlife, May 13, 2008, 11:27:44 AM
gotoluc
Quote from: nightlife on May 19, 2008, 12:07:07 AM
gotoluc, thanks for the video link. Is there any way you can test the amps of the collasping field you are collecting and post the results for us?
I could do that but I don't have the final commutator for the pulse system of the motor built or decided wet, so the efficiency is not good at this time. Last time I checked it was about 22 milliamp collected of the 120 milliamp supplied. However I feel that it could get better once I make my own coil to reasonate at the same frequency as the pulse of the motor (once I find out what speed it will want to turn at). I think with all these things in balance one could collect about 50% or more (I hope) of the energy from the collapsing field.
Luc
gyulasun
Quote from: nightlife on May 18, 2008, 09:21:04 PM
gyulasun, thank you for those links but they did not show what I was looking for. I was looking for a circuit that would utilize the collapsing fields in both directions from shutting off the coils in between the polarity switching.
When the coil is powered N<-------->P, the collapsing field is P<------->N but when you switch the power to P<------->N the collapsing field switches to N<------->P.
I was looking for a circuit that could utilize both directions of the collapsing fields.
Did This make sense?
Hi nightlife,
Yes, it did.  I have attached a drawing how I think this could be done first.
When both switches are in position A and you control them to switch to position B, the flyback pulse in L can enter C1 via diode D1. D2 blocks this flyback pulse from C2.
And when both switches are in position B and you control them again to switch back to position A, the flyback pulse in L can enter C2 via D2. D1 blocks this flyback pulse from C1.
So both C1 and C2 are able to store flyback energy in both polarity change periode until you utilize them by further circuits.
Basically you can use a H-bridge for the two switches.
Is this what you thought of?
rgds, Gyula
nightlife
gyulasun, thank you for that drawing and that was about the same thing as I was thinking of using. I can't beleave that I actaully made any sense. LOL
Thanks again.
petersone
petersone
Just an idea in the above drawing,uses both sides of coil and mags.
your comments gentelmen,(and ladies) any good?
happy hunting.
peter
