Bessler Wheel Theory by Alex
Started by Alexioco, May 14, 2008, 10:31:22 AM
hartiberlin
Hi Broli,
nice design.
In my WM2D it runs !
YOu need to sunstitute the fixed pins with pin joints.
I will do thislater, as I have to go to work now
and post it later..
Regards, Stefan.
Alexioco
Quote from: hartiberlin on May 22, 2008, 07:57:40 AM
Hi Broli,
nice design.
and post it later..
Regards, Stefan.
It Runs? So maybe this wheel is important?
? Bessler wrote:
MT13... This is a new weight-invention, with no belts or chains but each weight is separate and free except that each has an interval arm C with which it forms an angle, and on the cylinder hangs a figure which has below a weight in the shape of a half-moon and above a small wheel B over which the arms C sweep and lift themselves up at D. This invention would be very good for running if not so much friction were present or someone was available up by D to always lift up the weight with lightning speed.
If you look at MT 15 the bottom of the small weighted arms, they are also bent this way, but even if MT   13 was included, there are still two extra weights on the ascending side...
The love of God is great and true,
A special thing for Him and you,
A perfect friend, a Father too,
Lift up your hearts for He is true.
Alexioco
Could this be a working wheel?
Sorry that its rushed, this is how it works...
the square weights are lifted at the top like MT 13
they are all connected to each other like MT 9
they are also connected to each other like my wheel
could this be how Bessler made his wheel work?
@Alexioco;
Stefan said that it runs, not works. I still need to perfect it so that friction is absolute minimum. This can be done with some gear type mechanism. Then I need to slap wm2d around so that it gives me stabel results.
Edit: Currently I think your previous wheel is better Alexioco, before adding this one let us first play around with it.
Alexioco
Quote from: broli on May 22, 2008, 09:18:03 AM
@Alexioco;
How about the above wheel, does that hold any answer do you think or...?
