Is Lindsay?s ?SM? a fraud?
Started by RobotHead, May 19, 2008, 11:55:42 PM
wings
Quote from: wings on November 12, 2008, 07:56:58 AM
my be you have obtained two time the Einstein-de Haas effect in opposite way - one conuter the other one?
see Einstein's only experiment:
http://en.wikipedia.org/wiki/Einstein-de_Haas_effect
http://www.ptb.de/en/publikationen/jahresberichte/jb2005/nachrdjahres/s23e.html
....explanation here:
http://www.drjudywood.com/articles/erin/erin4.html:
    In this connection let us recall  the experiment of Einstein-de-Haas where  rotation of a  ferromagnetic placed in a constant magnetic field was demonstrated. This effect is explained by the fact that spins of a ferromagnetic initially oriented in an arbitrary way, under the action of a magnetic field have obtained a  primary orientation in a field direction. And if in an initial state  a  summary momentum of all spins  equaled to zero then in a magnetic field  it  had some non-zero value. According to the momentum theorem this leads to the rotation of a crystalline lattice in a direction opposite to spins. Beyond that point the inner moments of spins cause tangential stresses generating the torsional deformation of a ferromagnetic.
BEP
I think the links you posted do pertain to the reversals shared by @Otto. I am quite sure they pertain to my division of resonant frequency. Also, I would not be surprised if this angular momentum is the source of the famous songs of the TPU.
While I've never had the dramatic results, as described by @Otto, I do have coils that make an unusual wah-wah sound as if there are two frequencies very close to each other. That is with one frequency injected.
@Otto,
Did your broken core pieces show signs of twist.
@All,
My experiments were basically Rogowski coils with one end passed through the center (as a flat spiral - 1 or 2 turns) and the outer winding wound around that core 360 degrees and then reversed in direction and handedness the full 360 degrees.
Highest frequency division is found with fewer spiral turns.
The number of cancelling outer turn pairs should be an even number.
Spacing between the core and outer wrap should be at least 2.5 times the diameter of the conductor.
Spacing between the turns of the outer wrap should be as close as possible and less than 2 times the diameter conductor.
The results seem counter intuitive. The lower the inductance of the core gives a lower resonant point.
I believe the outer wrap is creating induced nodes and antinodes on the core conductor. 'Squeezing the hose' or pinching, so to speak.
It is possible to have a spiral coil that should resonate at 30 mHz (overall coil capacitance is increased) and find the coil current 'dip' (drop) near normal resonance divided by the 1/2 the number of cancelling outer turns.
Or even much greater.
There, I've shared details on the most easily repeatable result I've had these past couple of years.
To me, this explains the strange 22kHz resonance of experiments by others and extremely low points found on my other tests.
If you try this please be aware if you create a resonance that matches the mechanical resonance of your core there will be mechanical movement. Mine broke a pane of glass I was using as an insulating surface on my workbench.
Since the magnetic field is well known to be concentrated inside winding of a toroid this idea may be part of a TPU function. I can see a magnetic field rotating about this axis.
BEP
innovation_station
guys this is huge!!!!!!!
hummmmmm   things are clicking......
so 3 6 9 ....   30 60 90 deg quarture ...   360 deg  plus 3x 6 x 9 x the rings and the windings....   3.333 6.666 9.9999
12 crystals  12 vortexes plus the reverse   this fits rodins math some what i have not gone deep on this yet ....  but i bet if you map the colours of the torroide it works out with rodins stuff
russels vortexes fit in as transmitting and recieving for each coil
similar to this pic but walters shows all dirrections ...
ist
im drawing  lol
simple dwg
AND DOWN THE RABBIT HOLE WE GO........
sparks
      Pulse energy is just efficient use of changing the dielectric field about a form of mass.  Intrinsic energy of the mass or potential energy stored in the mass or at rest energy or resonant structuring of electromagnetic waves or photons  whatever you want to call it is there in vast vast quanities in just one little point in our 3 dimensional planes.  Is it the energy from termination of other dimensions who knows.  Electrons even though they are said to be drifting like when we heat carbon and there is thermionic emission they are still loaded with potential energy.  They still have angular momentum as well as axial spin momentum up the wasu.   It is this energy that the pulse exploits.  It frees the electron from it's relationship with the neucleus where the electron now expresses it's angular momentum and resulting magnetic dipole moments on the rest of space.   Now say we have a magnetic field like the Earth has setup or a permanent magnet for that matter  The electron UNDER IT"S OWN POWER drifts away from the mass it just got kicked out of.  The mass meanwhile is getting hungry for some electrons to restore it's resonance.  It's got more holes in it then it does excess electrons and this is where we get to have some fun.  Make sure the positively charged mass gets back into electrical balance by drawing charge carriers through an INPUT circuit.  Notice there is no output circuit in this sceanario at all.  This is why I believe SM's units heat up.  The circulating electron cloud starts to create eddy currents and infrared em waves xrays etc.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
innovation_station
i add this do u see this in the dwg i made...
ist
369 = 123 ;)
this time.....     i wonder what it feels like... to find the ONE....  in this LIFE...... the one we all dream of ...
but dreams just arnt enough ...  so ill be wateing for the REAL THING .....  ILL KNOW IT BY THE FEELING ;)
http://ca.youtube.com/watch?v=vP7VsPb9ZpY
8)
hey just play the chord....   can you make this vilon sing?!?!?!?! ;)
just to warp your MIND BODY SOUL what if i could start this from  a single pluse ...  and it was portable ...
what a dream to live.....    ;)
i would call it THE DEVICE OF THE UNIVERSE..... ;D
