Is Lindsay?s ?SM? a fraud?
Started by RobotHead, May 19, 2008, 11:55:42 PM
th3jester
@wings
I like the ideas and concepts of that guy but he doesn't give any hard edvidence that it actually works. Or even any real theory or circuit analysis behind his devices. At least his thinking outside the box.
@otto @all
I would like to see some good circuit anaylsis on any of the TPU's that have been built or are still in development.
But anyways I believe if someone actually did some good circuit anaylsis it would probably give you guys a better idea of whats going on and how to actually make it work the right way. Don't say there is already tons of anaylsis on the circuits because I haven't seen one. Putting the input voltage and freq is not it.
If you need "circuit anaylsis" explained just let me know.
giantkiller
The air core devices let the magnetic field reach the center at full velocity. The pressure will cause a spin in line with the direction of the pulse through the coil. When the pulse subsides, the earths magnetic field reconnects. The SM17 was air core although the drivers looked elsewise. Marco posted the Earth field reconnect 2 yrs ago when I posted the TPU in the Earth field horizontal to the ground.
I don't see much talk about the field model in real space.
--giantkiller.
wattsup
@otto
Thanks for your directives on how to connect. I did the connection expect that I presently only have one frequency generator (FG) so what I did was used two IRF840s in parallel but with only one frequency supplying both.
OK, just my bad luck when I did my first trials I did not write down what the frequency was but it was in the range of 1.6mhz. Anyways for the first time I could see some voltage rise on the load. On the 1000 watts bulb I also added in parrallel my humongous 1200v capacitor via a diode and there I put my voltage meter. Voltage went to around 34 volts. Never saw that happen before.
I was using my larger 10 amp dc power supply that doe snot have the current limiting like my other one, but voltage could only go to 20 vdc. I then started playing with the FG and from there I lost everything.
Oh yeh, I originally had the 840 on my breadboard but the board just smoked to hell. I now put the 840s in a good terminal holder with fatter wires. I had to double the + and - wires from the power supply. Eveything that was plastic like my red tapes to distinguish coils are now toast. Two of the four coils now have blackened wires so I don't know if I should rewind or continue trying.
My coils are with 22 awg wire but in your direction you are using .5mm (closest is 24 awg) so your coil wires are thinner then mine. I don't understand how you could be running 24 vdc into the and still have then survive. The device is basically one round toaster yoke. I could probably cook an egg in the yoke. lol
With my scope a 10x, I have seen some very weird things, that I have never seen before. I seems like there is also a delay from when you apply current and see anything special on the scope. Without making any changes, the scope changes by itself dramatically to some very bizare wave forms.
There is something happenning but it is difficult to separate the brute force driving power and the resulting effects. The bulb did not light but the system is just making smoke.
Anyways, I am looking for a second FG. I had a second one but it blew.
Last question, do you only put the FG probe onto the gate and not use the probe ground? I was not using the probe ground.
I am putting the diagram on page three here so others will know what I did.
Added:
Otto, on the diagram where we see the two top coil, where they cross over each other on the right there is a dot. Does this mean they are connected together all four wires. Just where it says 6" TPU, just below and between the P and the U. I did not connect it there.
BEP
@Wattsup,
If you are applying the signal directly to the gate and the SG shield/ground is not connected there is probably no way for the gate to drain or fall back to an 'off' state. Your MOSFets are probably staying 'on'. This would smoke things a bit.
Hope you had the makings of smores when you lit'er up  ;D
MACEDONIA CD
hi   all
  @th3jester   YES  YOU  HAVE RAID TO SAY     <<FOR  ALL SKEPTICAL  PEOPLE   YOU DONT BEALEAVET    ENYTHING >>   YES  THAT IS YOUr  real name  :)\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\
  if  all people   if be like you  the  texnology  todays   whill not be  exsithing now   <<maybe >>
BUT  FOR  ALL man kind GOOD   <<you tell as  to stop the test and  give up     <<
but remeber this  <,GOD   say be perfect and learn to be perfect  and make  beter  world as   like haven >.
  i like to say you    EVERTHING IS POSIBLE   EVERY  DREAMIN MIND   OF SOMETHING IMPOSIBLE   WHILL CAME  TO BE REAL   >>ALL  TEXNOLOGY TODAY  IS DEPEND OF  SOME   PEOPLE   DREAMIN  >>>
    I  LIKE TO SAY   <<IF  OK  S.M  IS  FAKE DIVICES      AND  S.M IS  MAKE  JOKE WHIT AS  OK
  BUT THAT JOKE  IS VERY GOOD    AND GIVE  AS  INTERESTHING IDEA S TO MAKE   THIS JOKE  REAL   AND MAYBE  WHILL AMKE  TO WORK   HIS  JOKE MOVE  TO REALYTY>>
athere
<<,im  have thing    OF  SOME   BOOK  OF  <,TESLA   HE SAID  WHEN IS FIRST TIME MAKE RADIO RECIVER  AND  ALL MAN  HO  SEE THAT   IS  SAY  WOW   HOW IS POSIBLE      THE  VOICES  GOING TO THE  AIR  hmm  AND THEN NikolaTesla   say  anther  yes  PEOPLE   THE  VOICES IS GOING  IN TO THE AIR  BUT  PICTURES  WHILL BE GOING IN TO THE  AIR      AND  THEN  ALL MAN THERE GET START  WHIT   :D    PEOPLE  HAS DONT BEALEAVET  WHAT HE SAID  <<,,BUT   HERE  AND NOW    THE  TESLA   DREAMING   IS CAME  TRUE   YES  PICTURES IS  GOING TO THE AIR  >>
                       @  ALL     DONT STOP  AND   MAKE   TEST   AND MAKE  BETER WORLD  FOR LIVING   <,EVERTHING IS POSIBLE>HMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMM  SORY FOR MY ENGLSH
