Is Lindsay?s ?SM? a fraud?
Started by RobotHead, May 19, 2008, 11:55:42 PM
otto
Hello all,
@Gustav22
thanks very much.
@All
I wanted to show you a new TPU design. I made it first with a Metglas magnetic alloy core. It worked good but the heating was a big problem.
So, the picture showes a STAINLESS STEEL CORE TPU. Not soooo a big heating anymore.
Collector coil: 9 turns lamp cable
control coil: 60 turns for each quarter, bifilar, wire diameter 0,5mm
core: stainless steel, 2 halfes, outer diameter 6", inner diameter 4"
Core cutted by hand , not to overheat the steel because the non magnetic properties would be lost.
This is just 1 half of the TPU because I see that another ring is needed.
Otto
poynt99
Quote from: otto on July 14, 2008, 05:05:24 AM
Its the first time that a conbination of 245kHz and 35kHz works somehow.
well unless you tried this combo with a 15 inch diameter device you wasted your time. but i guess you didn't pick up on the clue that diameter and circumference changes mean a change in frequency.
altium
Thank you very much, Otto.
What`s your frequencyes? Are the freqs sinhronized or you  just use 3 single independent generators?  What`s power consumption of your supply?
weri812
to Gustav22 and Otto
like your drawing
is the core wound in a bucking  byfold  like   N---N   ??
thanks
GOD BLESS
wer
PUT YOUR MIND IN GEAR BEFORE  YOU PUT YOUR MOUTH IN MOTION
wattsup
@otto
I don't get your new stainless core. You say it is 6" O.D. and 4" I.D. That will give you a 1 inch thick core. So how high is it? Please say 1/4". lol
Geez, how heavy is it?
