Is Lindsay?s ?SM? a fraud?
Started by RobotHead, May 19, 2008, 11:55:42 PM
sparks
    If say the copper gets hot enough to vaporize;  the normally matrix bound valence electrons start to express their kinetic energy outside the influence of the copper neucleus.  You get high energy emwaves like xrays etc. which could theoretically cause an avalanche of ionization of the copper and alot of heat and kaboom.  More probable is that the electrons start to circulate about the ionized copper field and you get a plasma.  This would be a good thing because the plasma matter stores the electron kinetic energy like a capacitor.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
Antimon
@chef
Have you ever seen an impulse voltage test with copper wire? That happens with the wire in your device :)
bolt
Explosions are the last thing you need to worry about you have to make it work first. Unless you have access to scopes, and RF test equipment analyzers etc forget it you never get a folded dipole working with 3 phase on 2 half's working perfectly in tune without it AND loop it after. You are 10 mio times more likely to die of electric shock LOL
My guess is it will take a 20+ year experienced HAM radio guy with excellent background knowledge and good build standards with access to this stuff to make it happen. Kitchen table top workers with a DVM from Rat Shack  will take you 200 years. So do the rotaverter stuff instead you can pick up a 1 HP motor for under 100 bucks, a car battery from the trash and a few caps and you will have results to show for your money and effort.
sparks
  @Bolt
      I think it alot easier to start off with a resonant circuit and modifying the inductor by placing conductors in the core of the inductor.  Something like a Tesla transformer with conductors inside the coil of highself inductance.
   So we have a coil of so many turns connected to a load.  Wrapped around this coil we have a coil of high selfinductance that produces a moving magnetic field.
Then around a portion of that coil of high selfinductance we wrap a primary winding which is resonant with a capacitor and provide input power to this primary resonant circuit.  If the output winding inductance and capacitance are matched the winding should be transparent to the resonant input circuit but not an external load.  So the magnetic energy normally going in and out of the core is resulting in electrical current flow in an external circuit.
Think Legacy
Spread the Love
innovation_station
does anyone have a spectrum anyilizer??
i was thinking of buying 1
to finish this thing off ......
but most likley not for a bit yet
just so much to build and finish already
ist
1 is needed  to do this properly and not cause interferience i have herd from other inventors that when u get it just rite you get a self contained plasma force feild  i was also told that when u are around this device and the engeries it produces that your hair stops growing
hummmm
oh btw my charger board is my osc....just drop a pot on it  ;)  i could do the same thing with a relay............ or a coil and a reed ..... 8)
1 million ways to switch it   TESLA  states you can use dc or ac....
i perfer to call my board in that setup a pulser rather than an osc....
all that is required for ou is the lil kick.... ;)
@ rosphere did you like the movie IRON MAN??  lol
