Is Lindsay?s ?SM? a fraud?
Started by RobotHead, May 19, 2008, 11:55:42 PM
Thaelin
   Would definately. What I was thinking of was 3 phase star wire up with input on one pair of wires
and a cap across the last one. Having two seperate 3 phase setups. If they are in series then it could not
be as I was thinking. Still, I am going to have to build this monster just to see what happens. What I need
is to figure out what size of coils would work well with 5000hz. Then the 15" was said to be 35k so that is
another animal as well.
   Then, the caps may just look as if they are in series. Just too much unknown. This thing has to run in
resonance or it cannot make the output as stated. What ever I do, need to do it quick. Gov shipped 800
billion in Ameros to a bank in china. What does that spell. Dollar kaput.
thaelin
Quote from: wattsup on October 14, 2008, 10:34:22 AM
@Thaelin
The LTPU big black caps are in series. Would that change the phase issue.
MACEDONIA CD
hi
  you say  for the cap black  <,yes is  the big caps    i think  is  <330 uf   450v  >.two in serial is   165 uf   whit 900 volts>
in one each cap has   one  big diode  <and is like this  <<<<<one cap  whit  one diode   anther  cap  whit anther diode >
the diode is put  in positive  pin of cap  >>anther end of diode is going to coil >
<<<<if you ask   how is posible   whit one diode to have  good  dc voltage  >> yes  can be  dc voltage
if you look the  simple switcing circuits  the secundary  out has  one  diode  for   positive   voltage  <<not  4 diode>
THIS CAPS IN   TPU IS  OUT  CAPS   WHIT ONE DIODE EACH <I THINK IS  IN THE SERIAL CONECTNING  >BEACOUSE  CAPS HAS  450V LIMITH  AND  TWO HAS  900VOLTS   >>  THE   TPU HAS  850 VOLT OUT
altium
Hi innovation_station,
can you attach the electrical schem, please?
wattsup
@Mac
As shown below, the caps are in fact in series when you move from this point a few more frames to see the rest of the wiring. But there are no diodes. These are simply bleed resistors indicating that this must be the output capacitors and they require to be bled when the system is shut down. Hmmmm. As for the cap values, i had tried many many times to catch the best image to see the value but no luck. I would guess they are 450 volts each to make 900 volts to equal the output voltage level of the LTPU.
Rosphere
Quote from: innovation_station on October 12, 2008, 02:27:23 PM
@ rosphere did you like the movie IRON MAN??  lol
What was your first clue?   ;)
The movie was not too bad.  My son wanted to see it, so I took him to the theater when it first came out.
I knew from the moment that I saw Tony Stark wearing the first "arc generator" that I had found my new avatar.  The basic conceptual similarities to the TPU were unparalleled.  Also, to me, the cave represented our little underground.  To top it all off, folks have told me for years that I look a lot like MDJ.
I cropped the photo from some internet movie promo' site just as soon as I got home from the theater.  You like it?
...now to make one...
