Is Lindsay?s ?SM? a fraud?
Started by RobotHead, May 19, 2008, 11:55:42 PM
Rosphere
@bolt,
I like the theory that you have put forth in your recent posts here.  It is quite different than the theory that spherics had posted.  I like both theories but I suspect that they both can not be correct.
Are you planning to attempt a replication with your theory?
BEP
@All
The color band style on the diode-resistor are of the diode configuration. The body appears to be the 'can' style. Look closely at the pic supplied by @Wattsup. The cathode end is identified as the end with the ridge.
The shape of the can style diode is very similar to the moderrn cola can.
Since the pic is B/W my best guess at the part number will be a 1N09 but could also be a 1N04.
I did a little digging and found the info on the attached document applied to that diode series. Look for the word 'harmonics' and the reference to picosecond cutoff.
If the caps are in series and these are diodes then another possibility for the circuit is a voltage multiplier for HF.
If the attached info applies then I can imagine the circuit doing super fast pulse generation with equally fast cutoff.
miroslav
hi all  :)
it seem`s that the on LTPU center toroid there are at least two wire`s that going half circle on cw direction and half circle in ccw direction ( may be  4 for each control coil) ?
zapnic
Quote from: miroslav on October 15, 2008, 02:53:45 AM
hi all  :)
aah good old mystery coil
"May be the direction of winding the small coils is also important
Starting the first "kick" comes from the magnets and the kick is a
result of the initial inertia of the free electrons is in the cable.
About the control, sure there are condensators, but i dont know how to
build it.
It could be so, that the small coils successively counter clockwise be
induced, so that there it a rotating magnetic field.."
hmmmm?
zapnic
Quote from: MACEDONIA  CD on October 14, 2008, 05:48:21 PM
hi
  you say  for the cap black  <,yes is  the big caps    i think  is  <330 uf   450v  >.two in serial is   165 uf   whit 900 volts>
in one each cap has   one  big diode  <and is like this  <<<<<one cap  whit  one diode   anther  cap  whit anther diode >
the diode is put  in positive  pin of cap  >>anther end of diode is going to coil >
<<<<if you ask   how is posible   whit one diode to have  good  dc voltage  >> yes  can be  dc voltage
if you look the  simple switcing circuits  the secundary  out has  one  diode  for   positive   voltage  <<not  4 diode>
THIS CAPS IN   TPU IS  OUT  CAPS   WHIT ONE DIODE EACH <I THINK IS  IN THE SERIAL CONECTNING  >BEACOUSE  CAPS HAS  450V LIMITH  AND  TWO HAS  900VOLTS   >>  THE   TPU HAS  850 VOLT OUT
hello mister Mac
i remember your video about toroid coil and the magnet's
eny new stuff about that thing?
bye
