Is Lindsay?s ?SM? a fraud?
Started by RobotHead, May 19, 2008, 11:55:42 PM
Grumpy
Where's Chef at?   He's missing all the fun.
        -Frank Edwards
Spider
I think he had some humble pie and chocked  :o  8)
Or he is busy with his chocolate balls....
Spider
Nice coils G. Thanks for sharing.
When a magnetic field, produced by a moving electric field, is moved longitudinally a tempic field is produced.
Grumpy
@ Poynt99, Peterae, Spider:
"Avalanche mode"
Watch the Joules through the switch - running high, start bouncing back and forth through the swich and "poof".
Spark gap will increase rise time.  PFN will help the fall.
        -Frank Edwards
turbo
Quote from: Peterae on October 23, 2008, 05:22:17 PM
Hi marco
I have not got that far with this build i am pulsing with 5us pulses at the moment, and cannot go too high in freq at the moment because of this, but i have used the same chips upto 10 mhz before during my delay line tests, i am not having any logic issues at all, the problem i have at the moment is noise on my psu's.
When i switch at 330 volts my rise time is 30nS and i am getting enourmous RF emission so much so that i can short my scope probe out with it's earth lead and read large pulses on the scope, it is this energy that is interfering with my psu's and logic, there is no reason why the logic will not go higher when i stop using the mono's and move to Poynts full circuit.
Once i have smooth operation at 330volts i will ramp up to 1500volts and then i will also add bias over winds.
The idea with my module setup is i can plug and play new modules as each prpgresses, in the mk2 i have changed my fet driver and fet to hopefully increase my rise time to 15nS, but first things first to get rid of the rf noise.
I am not sure what your issue is with logic but of course it is not unusal to run these chips at 100Mhz without concern.
Peter
Well maybe i am just a bad designer  ;D
My logic always get's what i call "infected"
This means it just stops responding for some unknown reason.
Offcource the RF fields can cause this to happen as they induce tiny signals in the components.
Anyway it looks like you are going to give it a real good try and i like that.
Good luck  8)
Marco.
turbo
By the way this is how i wrap them coils  :)
I used to work with number of turns, but these day's are gone.
Now i take one meter of the wire and measure resistance and then i just wind the calculated length to get to the proper total resistance.
So for example if the wire is 2 Ohms per meter and i need a 200 Ohm coil i just wrap 100 meters of wire onto the coil form and i end up with a 200 Ohm coil.  :)
Marco.
