Is Lindsay?s ?SM? a fraud?
Started by RobotHead, May 19, 2008, 11:55:42 PM
X-File
hi
Where I can start the exact coils and frequencies sine waves?
tks
Rosphere
Quote from: Rosphere on October 23, 2008, 08:25:11 PM
I am not inclined to change horses in mid-stream.
I appear to be riding the long shot.  Good thing that I am not looking for a racehorse; all I need is a good workhorse.  If this impulsive animal does not get me to the other side of the stream, then I may just need to get wet and sine up with another team.  ;)
I may be able to swap-out circuitry and drive the same coil configuration.
X-File
Quote from: Rosphere on October 23, 2008, 11:30:53 PM
Ok Understood.  :D
otto
Hello all,
when I made my ECD I was hoping we all could learn a little bit from this device, but NO, nobody figured out why my device was working so good. Or maybe someone builded in the meanwhile a better one?? Powered with 12V.
Maybe a year or more later somebody will take a few minutes of his life and just watch the video JDO300, Jason made. Maybe it helps??
@Marco
from your pictures I see you made very nice TPUs in the past.
Otto
pese
Quote from: bolt on October 23, 2008, 07:48:21 PM
For as long as you all keep banging coils with spikes more years will pass with NO results. The TPU works off pure sine waves to provide the initial magnetic rotation of a weak magnetic field.  The energy required is extremely low it does not need 20 amp power supplies a 9 volt battery is enough.
JES , i think, you have right!
This because any transformer can not transfer square wave , except you power this
with extremely extra power that will exceed his saturation.
But all this are losses !
Think about that the core need time and to change the magnetic polarities inner the corematerials.
only this way an "transfer (power.less) is possible to have good rendement,
souare-waves and also peaks
scratch distortion from the audio sources , sound unlike any amplifier that was
constructed before with transformer.
So i was always wondering that Bedini and all others will receive
power from squarewaves or pecks that is transferred with transformers
(because that produce LOSSES.  Only sine-waves will transferred with
small amount of loss !
If you must (will) transfer spikes (example from spark gap) it is
only to make (with high efficient) with "air-coil" (that can also transfer Sine-waves
0.5 Mhz to 500 Mhz with good results.
BUT if you try to receive power wit "harmonic responce of wave"
you must see "the natural waves" and understand that will (if)
only with sine waves.
Gustav Pese
