Is Lindsay?s ?SM? a fraud?
Started by RobotHead, May 19, 2008, 11:55:42 PM
Antimon
bolt, when everything is working on sine waves, why did SM use saturable reactors? I'm waiting for your answer.
You also have to go through Dr. Aspden's work. You will find some useful facts about the TPU.
The ether theory is "too high" for the most people, because they cannot imagine what is going on.
I'm looking forward that you are making a working TPU and show us the facts that you have found.
A.
bolt
Likewise if you layout on the bench ONE collector of about 50 turns of thick stranded speaker wire and 3 control coils say 20 turns single core door bell wire for the gate controls  you have no where to tap any voltage as you are working in two dimensions. Straight away you think of banging the coils looking for results but you only have HALF a dipole in front of you and even then no means of NON REFLECTIVE extraction.
The sine waves is ONLY the precursor if you make a 3D magnetic ball then you will get a stream of  kicks when its on the right frequency.  This is not theoretical its proven as one wire will jump when a current passes through it. SM told you to do this experiment as a teaching method to making a TPU.
What you can do though is layout and test the coils in rotorverter format (search this site for diagrams and info sheets) and find a run cap value to resonate plus you need a resonance cap across the collector coil.  You have to try a few coils and caps till you get 2D magnetic rotation verified by a compass. Try both Y and Delta. If you get this far you have made it further then anyone else on this forum that i can spot.
bolt
saturable reactor was almost certainly used for feedback control of the current loading. Its old technology and more proof that then TPU is using 80's technology.  They may be some twist where its required later but it shouldn't stop real proceedings in the meantime moving forwards and doing the precise stuff SM said that should be done.
innovation_station
i have done this..... ;D
bolt i have a super simple way to do this only thing is i did not use a compass i used a neo mag suspended on a string i did this long ago......
i have prototypes i choose not to share as almost no one has seen this effect
where are you erfinder ???
ready to talk yet???
@bolt have you ever studyied mpi?
how far down the rabbit hole is safe??
ist
in mpi where is the control curcuitry....   lol  there is NONE there is no need 4 it  ;)
@grumpy  this is G    ;)  HOW DOES IT WORK  lol
it aint hard ....   and you only need 1 control coil.....
Grumpy
Good luck with that direction, Bolt.
Like the old band "Black" sang back in the late 80's: "everything is coming up roses" -  ;D
By the way, a compass also responds to a changing electrostatic field -  :o
ROFLMAO!!!
        -Frank Edwards
