Is Lindsay?s ?SM? a fraud?
Started by RobotHead, May 19, 2008, 11:55:42 PM
giantkiller
Quote from: bolt on October 24, 2008, 01:06:09 PM
Likewise if you layout on the bench ONE collector of about 50 turns of thick stranded speaker wire and 3 control coils say 20 turns single core door bell wire for the gate controls  you have no where to tap any voltage as you are working in two dimensions. Straight away you think of banging the coils looking for results but you only have HALF a dipole in front of you and even then no means of NON REFLECTIVE extraction.
The sine waves is ONLY the precursor if you make a 3D magnetic ball then you will get a stream of  kicks when its on the right frequency.  This is not theoretical its proven as one wire will jump when a current passes through it. SM told you to do this experiment as a teaching method to making a TPU.
What you can do though is layout and test the coils in rotorverter format (search this site for diagrams and info sheets) and find a run cap value to resonate plus you need a resonance cap across the collector coil.  You have to try a few coils and caps till you get 2D magnetic rotation verified by a compass. Try both Y and Delta. If you get this far you have made it further then anyone else on this forum that i can spot.
This is a quick setup to do. And again, a field within a field. That is why Ed.L. stated to 'Ring the bell twice'.
@grumpy,
The prior year I lived between 3 airports and close to a top secret radar base. My testing went just far enough to keep me out of jail.
--giantkiller.
bolt
"You just apply a very fast pulse to a coil of high self-induction.  This causes the aether around the coil to polarize, then the pulse stops and the polarized aether suddenly depolarizes - this creates a shockwave in the aether, which causes it to move.  This in turn moves across your collector and induces an electric current along it.  An electric current can not maintain itself in a conductor so it must be utilized or it dissipates."
Grumps this is tesla / bedini, newman stuff its only 1st level tapping of BEMF type systems. All that does is pluck the magnetic earth flux which gives you 1.618 * Q but real switching loses mean you see only .323 RF gain yes RE = RF in extreme time compression return.   If you want REAL power like kilowatts streaming through you must open a permanent 3D portal. Its only when you do this the earth mag will come back with the entire global energy to plug the hole.  Thats why 100% tuned mag portal will come down and vaporise everything in 2 milliseconds.
There are 8 modes of power extraction.
giantkiller
Quote from: bolt on October 24, 2008, 01:48:46 PM
Very similar to the way a Sun spot works. A hole opens and one can see the plasma flowing into a black void. But energy is flowing into the hole across its diameter. Other wise the plasma just flows horizontally.
Occult aether physics and Dynamic theory of gravity both explain the aether around a mass.
Grumpy
Mag portals?
Bedini?  Ever seen Bedini or Bearden with a TPU?  Thought not.
3D portals?
8 modes of power extraction?
Unfortunately, Bolt, you are just about as WRONG as anyone can possibly be.
Back to the bench now...
        -Frank Edwards
giantkiller
In the beginning I posted a simple graphic of a ring and how it sits in the horizontal position between the layers of earth field flux. The flux is broken and reconnects layer to subsequent layer each on the same side of the ring, around the ring. It looks like water going down a drain.
Marco immediately reposted my pic with a point to point vortex in the middle. ( X ) Like this.
--giantkiller.
