Is Lindsay?s ?SM? a fraud?
Started by RobotHead, May 19, 2008, 11:55:42 PM
Grumpy
Quote from: bolt on November 01, 2008, 04:42:21 PM
Mentioned many times the importance of Q in my very recent posts and how to achieve it.
Sorry im not going over it again i said enough now. If you don't understand then its clearly got too complicated for you.
See Chef?  Bolt just folded. The pot is yours.
        -Frank Edwards
BEP
Quote from: Chef on November 01, 2008, 06:19:08 PM
Hmm... Maybe I am that stupid.
"W = (I1+I2+13)/3 x (V1+V2+V3)/3 x 1.732  * Q"
Where did you get that equation?
Hmmmm... Looks like he is averaging amps then volts and then replacing PF (Power Factor) with Q.
Balanced load three phase Watts = I x E x 1.73 x PF
Replacing PF with Q would really jack the numbers  ::) Now if you could change the Q of a circuit -after- it was charged that might be reasonable.
Mannix
pauldude000
@mannix
Yep, the hard part is the timing of the shots.
Finding truth can be compared to panning for gold. It generally entails sifting a huge amount of material for each nugget found. Then checking each nugget found for valuable metal or fool's gold.
pauldude000
QuoteBolt.......  The regen is vital its the ONLY way to make a loop at ELF appear large enough to grab some of the earth magnetic wave unless you stick a huge antenna to it.
Actually, it is not, but the thought of utilizing large fractal antenna's in such might be more than a little scary.  Too wideband, too much potential gain. Fractal collectors.....OUCH.
Paul Andrulis
