Is Lindsay?s ?SM? a fraud?
Started by RobotHead, May 19, 2008, 11:55:42 PM
ronotte
Hi all,
I've been requested from Otto to post this picture...for all to see :)
Cheers
ronotte
otto
Hello all,
WELCOME BACK ROBERTO!!!!
Thanks for the picture.
In this picture you see a coil wound over a cardboard. The diameter of the cardboard is maybe 12mm, or 1/2". The lenght of the coil is around 10cm, 4" or so.
The iron core is from a radio antenna. NOT SHINY!! Its of course almost black. Diameter of the iron core is 10mm. Lenght of this core is over 15cm, 6". It doesnt matter.
Number of turns is 50 with a wire diameter of 0,5mm  AWG ??
Now, what I want to know what happens MAGNETICALLY in this little coil. How looks like the mag field, where is the strongest point.....everything in the magnetic manner.
@Bolt
are you sure that we dont have to look anymore to single coils and wires. Are we already TPU experts???
Im NOT AN TPU EXPERT.
OK  experts, I hope I was clear what I want from you.
Otto
wattsup
@Neolystic
They were vertical four coil 90 deg each. I wired them to @otto's classic 4 coil wiring. Pulsed only two wires. lol But that does not matter. Any way you make it, turn it also on its side when checking with the compass.
Thanks for a good response. Regarding that photo, I think it is showing a coil energized with a steady power supply. The result will change when pulsing dc, ac sine or when discharging a capacitor, all also depending of the frequency.
@Roberto
How are you and how is the new garage lab?
@otto
The same would apply to your coil test, meaning how it is driven, will play on the field.
The 0.5mm = 23 awg. I will try it and let you know what I find.
Hmmmmm. 50 turns, now where did I hear that one before. lol
pauldude000
@Grumpy
Here is a little wake up call for you.......
I doubt very seriously that an AUDIO ENGINEER (SM himself) accidentally "tripped" over the TPU principle with his spectrum analyzer, USING HIGH VOLTAGE AND SPARK GAPS........
EXPLAIN PLEASE, why anyone in the audio field would be messing around with either?  The field of audio electronics uses neither high voltage (at least greater than mains 110v or maybe in certain amps 220v..... or 70v for the output).  Whats worse it never has.
SM outrightly pointed out in scenario after scenario that the unit is based off of 1. frequency resonation, 2. high speed moving magnetic fields, and 3. Rotating fields. Other clues were given for use with these basic three.
I love how people tag SM's name onto their own theories without even the possibility of his actually inventing the TPU using their concepts, and ignoring SM whenever inconvenient to their own theories.
Paul Andrulis
Finding truth can be compared to panning for gold. It generally entails sifting a huge amount of material for each nugget found. Then checking each nugget found for valuable metal or fool's gold.
innovation_station
well my last tpu does this but not exactly sm's way...
im useing 1 freq only ....  1k and 3 coils are switched phase 1 and the other 3 phase 2  to cause rotation altho ...   both rotating wheels spinn same dirrection   in my bucket or 6 freq unit both will spinn oppsite ways and controlled at will there will actually be 12 coils in my 6 freq unit
COIL HENGE ....
IST
