Thanks to ALL for your help!!
Is Lindsay?s ?SM? a fraud?
Started by RobotHead, May 19, 2008, 11:55:42 PM
innovation_station
when built properly this thing does not need diodes....
ist
pauldude000
Quote from: MrMag on November 10, 2008, 09:52:52 AM
Paul,
I don't fully agree with you. The spectrum analyzer was probably not needed or used. If he was using tubes the plate voltage could run up to 600VDC. As far as the spark gap, it could be a matter of a wire falling off and he placed it back on the post. He may have noticed something when the wire sparked.
Just guessing like everyone else :)
True MrMag, we are all just guessing. However, we will fall into the same condemnation of "they will never get it", if our guesses aren't based upon SM's concepts. SM was the one whom stated he discovered the frequencies with the spectrum analyzer while doing audio work. Most tubes used to make a class A, or class AB tube audio amp do not require anything near as high as 600v plate voltage (though I do know of various tubes which do use such high plate voltage). But you are right in that it could have been higher than 110v, as if my memory serves me the plates on some of the amplifier tubes could well go as high as 300v. I wasn't thinking about plate voltage in my statement. My bad, to quote the new vernacular.
Assuming the loose wire scenario is reaching, as it assumes both sloppy workmanship and electrical engineering ineptitude. Grabbing a loose 600v wire in operation (even with insulated pliers) is potentially fatal. Amateurs make this kind of HV mistake, which often involves a trip to the hospital.... or the morgue.
Making high end tube amps, SM would have known better, and shut down the equipment, and shorted the drive capacitors before attempting a reconnect in such a scenario. This is assuming he was building amps. However, if he was building high end speakers, the highest voltage used would be 70v.
**EDIT**
Actually MrMag, he could have been dealing with 500v..... I remembered that he mentioned something about TV VHF triodes in his amps.
Paul Andrulis
Finding truth can be compared to panning for gold. It generally entails sifting a huge amount of material for each nugget found. Then checking each nugget found for valuable metal or fool's gold.
Antimon
NO! He was dealing with electrostatic speakers, the voltage was over 5kV.
A.
giantkiller
aetheric control starts with electrostatic charge not discharge.
--giantkiller.
innovation_station
Quote from: giantkiller on November 10, 2008, 11:54:32 AM
--giantkiller.
indeed
hence 6 freqs as there 2 freqs of conversion..... ;)
you got a left and a right hand lol!!!!
first you must decide what you want if you want a power generator use square waves collect hemf  DONE...
if you want ag and all kinds of crazy shit   play the chords...   i bet there sine in perfect harmony.... 3 with the last rased ;)  or in reverse.....
ist
