Is Lindsay?s ?SM? a fraud?
Started by RobotHead, May 19, 2008, 11:55:42 PM
Antimon
Quote from: MACEDONIA  CD on November 11, 2008, 10:28:32 AM
hi to all friends here
you ask  i to show some batery <<THER IS NOT ENY KIND  OF BATERY HIDEN
AND MY INPUT IS ADAPTER HO IS GIVEM MAX OF  7,5 WHIT 1 AMPS  <<
<<BUT MY DEVICES IS NO NEED  ALL  7,5 WATT
HE ONLY PICK UP  <<7,5V WHIT 0,3 AMPS >>NO 1 AMPER ONLY 0,3AMP
I WHILL SHOW YOU ANTERE VIDEO  TO SEE  HOW IS BIG AND STRONG SPARKS  WHIT AMPS >
ONLY I SAY HERE IS OSCILATOR AND COILS MY OSCILATOR IS NEED ONLY 0,3 AMP
THE  FLAT WIRE ENDS  IF I MAKE CONTINUE  WHIT SHORT  THIS ENDS OF FLAT WIRE WHILL BE DISTROING <<NOT OF  VOLTAGE  BUT TO MUCSH AMPERS THER <<THE AMPS IS ABOUT 43 AMPS THER
THE VOLTAGE IS  190V
I HAVE 20 WATT BULB PUT THER AND MY BULB IS BURN FAST AND  BROKEN  ONLY 2 OR 3 SEC IS LIGHT THEN IS DISTROING
AND NOW YOU  SAY IS THER BATERY OR  ONLY VOLTAGE THER
YES  FIND ADAPTER LIKE ME WHIT THIS 7,5V AND 0,3 AMPS AND MAKE  YOU BULB TO DISTROING  20 WATT  IF MAKE THIS THEN YOU WHILL SAY THAT IM LIE HERE
THIS IS NOT JOKE   THER IS AMPRES PEOPLE WHIT 190 V
IF I PUT SOME  METAL FOR MAKEING SHORT  TO THIS TWO ENDS  IS HAPEND THIS
<<METAL  IS STIK TO HE TWO ENDS >
YES THER IS SOME FREKFENCY
YES THER IS  SOME SMALL VIBRATION
YES THER IS LIKE  <<S.M SAY TO MANNIX   IF YOU HAVE 1000 PARALEL WIRE  AND FAST BULYTH SPED MAGNET MOVING FILD>
AND ATHER THIS MAY DEVICES IS NOT WORKING OF SOME  STRONG ELKTROMAGNET FILD  IS NO NEED THIS FILD TO PRODUCED  THIS STRONG AMPS IN TO MY COLECTORS COILS
ATHER STRANGE THING IS HAPEN HERE
I HAVE NOTICE THIS
WHEN I MAKE OSCILATOR TO WORK IN MINIMUM GIVEN INPUT TO OSCILATOR THEN MY OUT COILS GIVE SO MORE POWER IN THE OUT
IFTHE OSCILATOR GIVE MORE milli AMPS   TO TPU THEN THE OUT ENERGY IS LOW DOWN AND NOTHING
YES THER IS VIBRATING ONLY MY COLECTOR s coils probuced this
ask for you  <<i like to ask one friend  here  if you find this man <<nick name <<
<<tao>> hello tao
tomorou i whill make anthere video to shoow how is distring my flat wire  of my out oils
thanks by
190V and 43A. I see you never saw an arc from such a powerful source, because you will not stand nearby when you short the poles.
A.
otto
Hello all
TPU experts.
Yes, Im sarcastic.
In my picture you can see  the kicks. At high frequencies they are oridinary kicks.
The magnetic field is like we learned them from our books.
Then, when I tune this frequency to a lower range something happens: I see a little additional kick is "born". This is the 1. harmonic!!! In this moment my little magnet hanging over the coil showes me that I have now a contra magnetic field: The North pole is now the South pole!!! and the South pole is now the North pole.
Also, my little magnet showes me that I have the South pole covering 50% of my coil and the other 50% is the North pole.
When I again tune slowly to a lower frequency I see there is "born" another little kick so I have 2 little kicks. This is then the 2. harmonic but the mag field is NOT changing.
Again tuned a little, I see a 3. little kick is "born" and the mag field is again changed S to N and N to S.
This is my 3. harmonic.
If I would continue......
We have 35kHz and 245kHz in our TPU. This means the 7. harmonic....
The moment when the magnetic field changes the poles is the moment where you have to take care of yourselfe and your equipment because......
more tomorrow.
I really dont know why the hell Im wrighting this because you all know this very well.
Otto
Antimon
Great experiment, otto!
Cool results
A.
otto
Hello all,
thanks Antimon.
I didnt wright a lot of my findings but I forgot something very important.
All mentioned works with a core or without.
With a power supply connected but the most dramatic results are when I use a car battery as power supply.
Maybe the people will understand what I gave them.
This results can use anyone working on pulsed coils.
Otto
Neolystic
Awesome Otto!
Lots of people here should find your results very useful, not just in the TPU section.
Neo
