MT 10, 11 and 13 Combination
Started by Alexioco, May 28, 2008, 11:25:36 AM
Alexioco
Here we go again, I have come across something else you should all find interesting...
Lets go one step at a time...
MT: If the levers are reversed then we get this...
Now when the weights are like this,  you can make the weights fall into the centre near the bottom and fall out near the top which is good...
Now if we look at MT 11 its doubled and Bessler says there is more in it than meets the eye as you will see when he pulls back the curtain...
Well keeping MT 11 in mind, look at MT 13, the extra bit are lever used for going over the wheel at the top can be used in another way, if you more of those extra bit of levers, you get this...
Now go back to MT 11 and put the inner weights inside MT 13 and the inner weights when they fall back can lift the outer weights up, also if you reverse a few things in MT 13 then the weights can fall forward and lift the weights that way to...
The love of God is great and true,
A special thing for Him and you,
A perfect friend, a Father too,
Lift up your hearts for He is true.
martinzurix
it finds equilibrium point and stops !!!
Quote from: martinzurix on May 28, 2008, 11:30:40 AM
Thanks genius.
Alexioco, could you explain/illustrate more what you mean by  "also if you reverse a few things in MT 13 then the weights can fall forward and lift the weights that way to..."
martinzurix
this system is closed loop ..  there no energy flow.
energy used to lift up weight in cycle start position is equal to falling weight energy .
gravity is like water pressure in sea.  it is force witch dark mater pulls from outer space !!!
Quote from: martinzurix on May 28, 2008, 12:38:23 PM
I don't remember anyone asking your expertise sir. So please buzz off if you have nothing constructive to share.
