Cancer cure, but FDA and doctors would rather have your cash and not the cure.
Started by b0rg13, May 30, 2008, 07:59:29 PM
jibbguy
Here is an great documentary by Rick Simpson (who was on the earlier radio "Ron Paul Revolution" interview) called "Run From the Cure".
http://user148333.websitewizard.com/thc-the-cure-for-cancer.html
Hemp oil is a cure for cancer... It's not just him that is saying this... Clinical studies have shown it as well (oddly enough, always from Europe or elsewhere outside the U.S.) . Simpson gave the oil to his friends and neighbors in his little town in Canada, and at least 2 were cured of terminal cancers; and a whole host of other diseases.
Imagine this knowledge being known to the medical community: And not being acted on.. What does that say about our current society?
When Social Security was enacted, people were expected to work until age 65; and die at age 67.
People who use chemo or radiation treatments die at a higher rate than those with cancer who do not.
No one has ever died from cannibis.... Ever. It has been used as a medicine for over 4,000 years.
Supposedly 1 pound of high-quality "grass" buds is needed to render 2 liquid ounces of hemp oil (but that should be enough for the cure, taking about 3 months). Simpson said that you can smoke un-concentrated marijuana "until the cows come home", and it will not cure any cancer; it must be in the oil form.
But note: Processing the hemp oil can be dangerous. Toluene or Isopropyl Alcohol is used as the solvent.. Then it is boiled off in a rice cooker (outdoors with lots of ventilation). He shows the process in the vid.
professor
Quote from: amigo on February 28, 2009, 06:27:00 PM
Ah but it's not "Global Warming" anymore, it's "Climate Change" so now it covers any possibility and they'll always be right, hehe. :)
It was a nice and cold day today and I see snow for the next week, nice. As you said the warming is in Australia... :)
I got the point of the buffer and the need for MOSFET for high impedance. I will stay away from tubes. :)
Because it is DC, it is micro-currents that need to be introduced, right? Have you ever found a place where they talk about the necessary voltage to penetrate specific layers of the skin. We still need to somehow figure out the threshold for the blood electrolysis and stay the heck away from it...
Your ingrish is just fine. :)
Thanks.
Hi Amigo
50 to 100 microamps directly into the Bloodstream If you were to stick a needle into the arteries  which I will not do you might get a better reading although there is quite a span between 50 and 100 . If 50 will suffice then stay away from anything higher .
I visualize it  as submerging the soles of your feet into a conductive (Saline) or epson salt solution in a stainless bowl.
This would be one of my electrodes and the surface area being that large a greater amount of current must flow in the lower ma range.The other electrode could be your hands using the same setup or using as most do a small probe above the inside wrist directly over the visible  vane.
If you took a reading anywhere on your Body in between those two points  preferably the bloodstream in the vane you may have a clue that the current is successfully flowing throughout. Like tapping a resistor .
Density or resistive Data of the upper dermal layers, I never heard of it.
I think we are trying to make an Elephant out of an Ant Hulda is using 27 VDC and so is Beck.
However Beck specifies somewhere the size of the Electrodes in Square inches if attached to your wrist.
It was rather small and you can get burns and lesions on your skin.
With my method you will not.
With an alternating phase  you may prevent electrolysis  like you can not plate metal using ac or switched DC I think
correct me if I am wrong.
Finally warmed up here to plus 3 .You can keep all your snow.
professor
amigo
Hi professor,
People have used Stainless Steel electrodes that were wrapped in fabric and soaked in a saline solution. They would get burns and lesions on the spots due to bad conductivity (the saline solution would try). Some have suggested using Silver or Gold as an alternative but somehow I feel it would be the same.
I was thinking in the lines of using carbon electrodes (graphite). Our cells are carbon based so I figure it would not be rejected or cause burns, although I did not try this so maybe I'm wrong.
Regarding your setup idea I am sort of awry of an idea of submerging one's feet into a bowl filled with a conductive liquid. You do know that anything above 1mA will produce a sensation, 10mA muscle paralysis, then we get a respiratory failure, severe shock, etc. and the threshold of lethal current is above 100mA, with 500mA possible heart fibrillation.
You simply do not ever want to pass more than 100uA to your body, if at all that much, and definitely battery power only.
For example, between a hand and the foot resistance is about 500 ohm (or much less since you submerged your foot in a saline solution). When you run 30V DC you are passing 60mA through your heart (remember both feet in water, electric bridge) another electrode to the hand. You might as well "waterboard" yourself if you like torture :)
I think we should just stick with the wrist electrodes and 50uA, add a MOSFET buffer and use battery power... :)
Oh, looks like they changed their mind about snow, now they say Sunny and rain on Wednesday. This Climate Change thingy really works...
tishatang
Hi all
Interesting link here:
http://www.royalrife.com/megamagpulser.html
"Dear Group,
I've been really serious with my investigations into the uses of this device. with the help of an electronics engineer, I have determined that the coil should be made from 250 feet of wire if you are using 10 gauge (single strand). I have also made 2 other smaller coils using 12 gauge multi strand wire......each one using 100 feet each (or more). I am now using two batteries in series equaling a voltage of 24. The best button I have found for using this device so far is a "horn" button which I bought at walmart for 3.96. Actually each of my coils have their own button and it works VERY well. You can tap it for the shortest and fastest pulses. As for the effectiveness of the coil, I have spent thousands of dollars on gadgets and gizmos and supplements to try to get rid of this dreaded lyme and nothing has worked. There is something totally different about this device. The stronger I make it, the better it works. I am having the most severe herx symptoms that I have EVER had......this is the first time that I've felt bad enough from die-off to want to stop treatment but that is exactly what I did today........I was pale, and lethargic and in alot of pain from dead pathogens in my joints and blood........but I spent the whole day smiling because I've NEVER been this successful. My wrist coils (because that is one of the first places I want to clear of this disease) are doing their job and both wrists were on fire today from the die-off.........in fact I'm probably over-doing it a little.....but I had no idea it would be so effective......... I am also very excited because of what this could mean and do for some of the rest of you.....Lyme is notorious for being hard to kill......and this is killing it for sure.........hep-c isn't hard to kill.....but is very hard to reach........this may be the answer!!.........
I really feel this is the answer for many of us........This is the FIRST electric device that has been effective for me.......I've never doubted that I would find the answer but I didn't think it would be this.......I have every confidence that steadfast use of this coil will help me kill the beast............
By the way.....it seems that taking something like grapefruit seed extract while you are doing this coil treatment.....they seem to compliment each other very much......................More later when I know more!!.........Robb 12/1/03
[/sub]
Build the megapulser and maybe you don't have to worry about electrodes and the skin burning issues?  Just need deep cycle battery, lots of heaving gauge wire and a starter solenoid energized by a horn button.
Tishatang
professor
Quote from: tishatang on March 02, 2009, 04:32:46 AM
Hi all
"Dear Group,
I've been really serious with my investigations into the uses of this device. with the help of an electronics engineer, I have determined that the coil should be made from 250 feet of wire if you are using 10 gauge (single strand). I have also made 2 other smaller coils using 12 gauge multi strand wire......each one using 100 feet each (or more). I am now using two batteries in series after being equaling a voltage of 24. The best button I have found for using this device so far is a "horn" button which I bought at walmart for 3.96. Actually each of my coils have their own button and it works VERY well. You can tap it for the shortest and fastest pulses. As for the effectiveness of the coil, I have spent thousands of dollars on gadgets and gizmos and supplements to try to get rid of this dreaded lyme and nothing has worked. There is something totally different about this device. The stronger I make it, the better it works. I am having the most severe herx symptoms that I have EVER had......this is the first time that I've felt bad enough from die-off to want to stop treatment but that is exactly what I did today........I was pale, and lethargic and in alot of pain from dead pathogens in my joints and blood........but I spent the whole day smiling because I've NEVER been this successful. My wrist coils (because that is one of the first places I want to clear of this disease) are doing their job and both wrists were on fire today from the die-off.........in fact I'm probably over-doing it a little.....but I had no idea it would be so effective......... I am also very excited because of what this could mean and do for some of the rest of you.....Lyme is notorious for being hard to kill......and this is killing it for sure.........hep-c isn't hard to kill.....but is very hard to reach........this may be the answer!!.........
[/sub]
Tishatang
Yes I think you are right.
This however is a method for a known disease and to be localized rather than treating your entire Body and the blood that supplies you body throughout.
I know of a similar and more effective way by using  a Higher voltage of  330 VDC  and a series of Photo flash Capacitors
after being fully charged you discharge them via a SCR  into a Load which in this case was a Speaker crossover Coil  of heavy enough wire to handle the Current,or find an old Photoflash and convert it for such purpose.
It however will not treat your Blood and therefore it will have different applications.
Those are items you can get at Radio Shack or other Suppliers as they are cheap and readily available.
With the SCR you will  have no arcing and a fast discharge,but a switch like in your case will do.
professor
