Cancer cure, but FDA and doctors would rather have your cash and not the cure.
Started by b0rg13, May 30, 2008, 07:59:29 PM
professor
Quote from: amigo on March 01, 2009, 10:31:05 PM
Hi professor,
People have used Stainless Steel electrodes that were wrapped in fabric and soaked in a saline solution. They would get burns and lesions on the spots due to bad conductivity (the saline solution would try). Some have suggested using Silver or Gold as an alternative but somehow I feel it would be the same.
I was thinking in the lines of using carbon electrodes (graphite). Our cells are carbon based so I figure it would not be rejected or cause burns, although I did not try this so maybe I'm wrong.
Regarding your setup idea I am sort of awry of an idea of submerging one's feet into a bowl filled with a conductive liquid. You do know that anything above 1mA will produce a sensation, 10mA muscle paralysis, then we get a respiratory failure, severe shock, etc. and the threshold of lethal current is above 100mA, with 500mA possible heart fibrillation.
You simply do not ever want to pass more than 100uA to your body, if at all that much, and definitely battery power only.
For example, between a hand and the foot resistance is about 500 ohm (or much less since you submerged your foot in a saline solution). When you run 30V DC you are passing 60mA through your heart (remember both feet in water, electric bridge) another electrode to the hand. You might as well "waterboard" yourself if you like torture :)
I think we should just stick with the wrist electrodes and 50uA, add a MOSFET buffer and use battery power... :)
Oh, looks like they changed their mind about snow, now they say Sunny and rain on Wednesday. This Climate Change thingy really works...
Hi Amigo
I have used a Couple of Silver Ingots as Electrodes.
You might be right with using Carbon as electrodes.
I thought about that myself as you know for production of colloidal Silver there must be no additives to the Water  so using silver and salt maybe not such a good idea.
I have tried the saline solution in a Stainless  Bowl and I had a Variable output through a Pot but limited in series with a Resistor
as to prevent more than a given amount of current to flow.
I am still alive Electricution is a combination of Voltage and Current. You can hang onto your Car Battery Posts with both Hands
and although it is capable to supply 300 or more Amperes you wont be electricuted.
I have had a few zaps of 25 KV from TV sets during my Life and other than being painfully unpleasant it showed no ill effects.
On the contrary it may have zapped some of the pathogens ?
If in Doubt just insert a Milliamp Meter into the Supply Line .
Even if you ran a current of 1 ma through your Body the current that would run through your Blood would be minuscule.
professor
Bob Smith
QuoteWithout having looked at your circuit  I just want to show you one very stable circuit that puts out a variety of waveforms.
@Professor, thanks so much for taking the time to post the circuit. Much appreciated.
All the best to you,
Bob
amigo
Quote from: professor on March 02, 2009, 04:55:03 PM
I know of a similar and more effective way by using  a Higher voltage of  330 VDC  and a series of Photo flash Capacitors
after being fully charged you discharge them via a SCR  into a Load which in this case was a Speaker crossover Coil  of heavy enough wire to handle the Current,or find an old Photoflash and convert it for such purpose.
It however will not treat your Blood and therefore it will have different applications.
Those are items you can get at Radio Shack or other Suppliers as they are cheap and readily available.
With the SCR you will  have no arcing and a fast discharge,but a switch like in your case will do.
professor
We must have seen the same circuit, it's been floating around the Net for awhile. The premise is based on Bob Beck's idea to use magnetic pulses to stimulate lymph centers, where he said pathogens collect, and expel them out. All this should be done, according to Beck, in conjunction with his other "treatments", thus the Beck Protocol. :)
amigo
Quote from: professor on March 02, 2009, 05:16:11 PM
professor
Hi,
So my next question is: "Did it work and did you notice any difference?"
Though, we are back to square one because we can't reliably detect anything and all results are based on subjective observations, that vary from person to person.
PhiScience
The function of science is to make observations and measurements and to find correlations between the observed facts.
