I seem to have Negative Electricity but what do you do with it?
Started by gotoluc, May 31, 2008, 04:58:24 PM
gyulasun
Hi Luc,
Could you place a resistor of 47-100 kOhm value in parallel with the output voltage and see the output voltage then?
The resistor would serve as a useful load and in case the voltage may decrease to less then 400-500V, then you could check it with an oscilloscope the amplitude and the waveform.
(I guess, there is also a possibilty that the EM fields of the spark may fool the inside electronics of your otherwise excellent Fluke meter)
rgds, Gyula
Goat
@ Gotoluc
Could you try to store the voltage across a capacitor bank also, I'd be curious to see if you couldn't gather it that way also. Then measure the cap once the system is down to avoid EM while it's running.
Regards,
Paul
zerotensor
gotoluc
Thank you all for looking :D
I will do the recommended tests as well as I can and try to get to the bottom of this. I will post if I find anything new.
Luc
gotoluc
Hi all,
here is an updated video which has a much better result ;)
Link: http://www.youtube.com/watch?v=vsDccdEcPx4
Thanks for looking and if you think this is good share it with everyone you know.
Luc
