Magnetic Permeability ... I can't find anyone talking about this !!!!!
Started by The Observer, June 02, 2008, 02:38:15 AM
xee
@Observer,
You are using equations for after steady state current (which is after domains are lined up). The work is needed to line up the domains during the turn on transient current increase. To see difference in work you need to integrate current over time required to reach steady state.
The Observer
Hey Xee,
Thank you for your reply.
You are saying that it takes quite a bit of force and time to turn the atom dipoles?
Thus inferring that the extra energy (work) has to do with the time and force required to turn them.  hmmm
The time it takes for a piece of iron to be attracted to any magnet...is virtually nill, the last time I checked.
This is the time it take for the dipoles to line up that I am referring to.
As for the force to turn them... I don't have the statistics, but it ain't much, this is why they turn so fast.
Ever heard of NMR?  Dipoles can be set to spin for a relatively long time after the right frequency is applied.
                               I think the friction can labeled as negligable.
If you really want to challenge this, please come up with some formulas or something concrete.
Please do not assume your high school physics teacher (and the oil companies) are right when it comes to
   the notion that we must pay for energy. This is an AGENDA. The physics teacher just doesn't realize it.
"Ah Ah, you can't do that because someone told me it can't be so..."
This is where many get stuck... judging because of brainwashing as opposed to just observation.
By the way, there are numerous patents for magnet generators that use a small amount of electricity to produce a greater amount of electricity or power.
I am saying, this is how and why they work.
Refer here .....  http://gabydewilde.googlepages.com/magnetmotor-inventors
If you have been brainwashed enough.. you will say that the patent office has wrongly issued these patents. lol
(not all need electricity to work, I am referring to the ones that do)
Gotta go...
             The Observer
fritz
Another thing is - that as long as there is no core -
the B is only limited by the current the coil can handle.
If put in a core with ur - this core has a maximum B -depending
on the ur. Cores with high ur have low B ratings and vice
versa.
Just look into datasheets.
The core bundles and focusses the magnetic field - this gives
it more power and strength to the "outside" world - so it looks
like the "power" increases. If you set up the differential equations
for the magnetic vector potential (which sould be easy with a master degree)
- you will see. Or try it out.
If you move the plates of a charged cap - the charge stays the same -
only the voltage changes.
If you move a core into a coil - and ignore the energy balance of
the power used to put it in or pull it out its similar.
The Observer
Hello again,
By the way Xee, I do think you did bring up a very good point that needs to be understood.
Thank you.
I will definitely investigate as that I may come up with a concrete explanation myself as opposed to a loose justification.
Sincerely,
               The Observer
xee
@Observer,
Yes, it takes time for domains to turn and some take more force to turn them than others. I do not seem to be much help to you. Perhaps someone else can explain better. I give up. You also might try re-reading your physics books.
