3L/min hydrogen not enough?
Started by greenhydro, June 04, 2008, 01:37:52 AM
Creativity
i send u a PM on how to get my posts. Well all this plans going around are worth something. In few words addition of H2 speeds up the fuel burning proces and gives possibilities to adjust and further fine tune ur engine so it will be more efficient.Untill some (for me still unknown) percentage of H2 in fuel,advantages of it can outweight the energy used to produce H2.The better the engine tuned to the newer conditions the more u will get back of it.Stay tuned to this forum.
Blues it through your outstanding life,leaving more than just footsteps behind (1999 B-stok by me).
By being intensively responsive to what others say,i do run a risk: I open myself up to the opinions of others.i will,at times, have a great understanding for their opinion.Sometimes,i will even change my own opinion because i realize that the other person is right.This "risk" i do not run if i am unresponsive to what others say.
hunter
I don't say those size of generators are crap, but not big enough (10-20% fuel savings max). So what I'm saying is 1-2L/min HHO is stil better than nothing, so go ahead make one and try. But if you want some serious amount of gas, you have to build a much larger unit, and that one will not fit in the engine bay, you have to put it in the trunk or in the cabin, like I have in my Windstar and run it from pulse. Also you will need O2 extenders and a MAP sensor or a EFIE depend of your car. If you will run it from starit DC I suggest you to get a 30amp. PWM controller. That is all I think right at the moment, may be someone has other idea too.
powercat
Hi hunter
Can you give us info on your PWM ?
All i can find is two http://www.pwmpower.com/ and http://www.vptechno.com/d14PWM.html
pc
hunter
I'm talking about the PWM DC motor speed controller 30 amp rated. If you run your generator from strait DC you need it to control your amp. But the pulse generator you are asking about, I will buy it from this guys. http://www.aquapulser.com/index.html  Looks more professional. I also would like to hear some test results regarding any of these pulse generators, if any one of you did try them, or using it.
powercat
Thanks  hunter for the link
QuoteI also would like to hear some test results regarding any of these pulse generators, if any one of you did try them, or using it.
heres one by NerzhDishual  http://freenrg.info/Exp_With_DallasGB_Elect/
hes on the form  http://www.overunity.com/index.php/topic,4302.msg102382/topicseen.html#msg102382
pc
