Konrad Baecker Magnet motor converted from a DKW car motor
Started by hartiberlin, June 05, 2008, 05:03:07 AM
ceres
@Helmut,
Wie sehen sie sich dann die verfuegbare patente die ich gegeben habe in Ruhe an?
Was denken sie dann? Haben sie Over Unity Potenz, so ja, warum, so nein, warum nicht?
Herr Konrad Baecker hat gezeigt wie sein adaptierter DKW motor laeuft, also, was bedeutet das? Overunity mit einem Nordpol oder Suedpol motor?
Kann es wirklich klappen mit Elektromagneten zusammen mit permanentmagneten in der selben Art und Weise als Baecker hat gemacht mit Ferrit Magneten?
Das war in 1986, dasselbe Jahr worin Tschernobyl hat "geklappt". Auf primitivsten Sowjetischen Art und Weise so zu sagen.
Ceres
Dact
Re: "Locked" current problem solved in Magneto designs
? Reply #1 on: June 27, 2007, 09:53:29 PM ?
   Reply with quoteQuote
Smiley
If you really solved this, then you have just possibly solved the problem of converting existing internal combustion engines to magnetic power, by only removing the piston rings(no compression needed), chamber oil, mounting a permanent magnet on top of the piston, and replacing the heads with electromagnets powered by a magneto! Just a thought!
I have been toying with this idea for quite a while, and I truly think it will work! Think of the implementation savings in years this would afford!
Due to financial and physical limitations, I was not able to produce a prototype, but I did model it in WM2d and it worked there, though with mixed results, probably due to my lack of experience. Please encourage anyone out there to continue this approach. The quote below is a reply to "Honk" from may 10th. I hope it encourages others to investigate this concept!
Quote17       Mechanical setups / Magnet Motors / Re: Reciprocating Permanent Magnet Motor Concept       on: May 11, 2008, 06:38:29 AM
Quote from: Honk on May 10, 2008, 08:58:16 PM
No magnet motor based on balancing the forces will work. Whether you use shielding or not.
This have been tried over and over in all thinkable combinations over the years.
Hi,
The aspect of this concept that intrigued me was not the balancing basis, but the reciprocating part. I believe that it is possible to convert a standard gasoline engine to a magnetically driven one, cheaply, as outrageous as that sounds. The advantages to such a conversion are obvious! The world is already clogged with autos, and there is simply no time left to replace them all with a new, designed-from-scratch power source. However, if all that was needed was a fairly inexpensive modification of existing engines, it would save billions in precious resources, such as iron, and could eliminate fossil fuel consumption in the land and water transportation and power systems. But time-to-implement would be the biggest savings.
Your obvious question is how? I am working on a model right now, and in the next few days will post it here. Hint: The answer, of course, when it  comes to magnets, is how to overcome all the limitations of previous designs, and the answer is initial power to start the process. We already have it in common use today.
I have been following your posts for a while now, and respect your insight greatly. Hopefully, you will please take a serious look at my proposal.
Until then,
Respectively,
Dact
Good luck1
Dact
"Terror hearts out, always;
Terror fabric, NEVER!"
Walter Hofmann
Hi stefan
the original ford model T4 should have been capable of running on magnets in acordance to some info about ford beingthretend by the oil companys at the time he declared them if they dont stop threaden him he would send all his T4 customers a set of magnets and then they would need no petroleum at all. thats what Ed ledskalnin has used you can see the remain in the picture where he used a model T engine block with the flywheel still attached and there are the V kind af magnets .
the old magneto from the DKW ( a re engieniered version was the P50 in the DDR) was build similar it worked as a starter and generator with a bloc k from them and all the cylinder piston etc. removed it did run after push up on its own.
I just thought to put ,y experience from the time here .
greetings
walt
Quote from: hartiberlin on June 07, 2008, 07:18:08 AM
Okay, here is now the full PDF file for the patent for the movie
I uploaded.
http://www.overunity.com/index.php?action=tpmod;dl=get84
With todays Neodymn magnets this motor must be a real good alternative
and normal motors could be converted to it.
Regards, Stefan.
ceres
Helmut,
I am afraid English and not German language is here to stay.
Hello all, hello Walter,
This is interesting you come up with Leedskalnin and T-Ford model being also fit to receive magnets. I found Leedskalnin's book 'magnet current'. Veeery interesting to see all his experimenting. Great to see the total absence of mathematics, this is how exciting physics can and should be. We do not need mathematics at all, OK, in the end, after a successfull experiment we could decide to start doing some math.
He also did a little experiment with an iron cored coil surrounded by an iron tube. I wonder how Baecker's configuration can be explained in terms of changing the magnetic path temporarily by electric pulse in the iron cored coil placed transversally into the tube-formed permanent magnet. Also why not so much electric energy is needed to change temporarily the flux's path in order to get the magnet piston in TDC for the power stroke.
You are talking about a picture of Leedskalnin's experimental T-Ford-engine. Can you upload it?
Also do you have any references where I can find more information on this episode of unfriendly exchange between Ford and Oh Lord All Mighty Oil?
Do you have references or info on these kind of Leedskalnin's experiments?
This is the link where I found Leedskalnin's 'magnet current' book, published Rock Gate 1945.
http://www.scribd.com, you have to register though, it's a simple process.
A lot of interesting electronic books. e.g.. 736 pages 5 books of Noam Chomsky on politics.
Are you aware you can find many patents in the patent databases which describe this principle of permanent magnets in the piston and electromagnets in the engine head, engines claimed to be running by themselves without any fuel?
Ceres
Walter Hofmann
hi ceres,
yes I got picture ( my own of all the equipment what was left after gouverment raid on ed's property I was there a few times. I will upload them over the weekend.
I have to look for the info on ford.
thanks for the link
greetings
walt
Quote from: ceres on June 11, 2008, 05:56:09 AM
Helmut,
Ceres
