Who is generating 5 Litters of HHO?
Started by 22350, June 05, 2008, 06:04:22 PM
BrianM7625
I've been building HHo's for about 3 years. It took a long time to figure out how to keep them cool and to keep the amps from running away. I have put two liter plus units on a VW diesel, his mpg's are around 70. 1 liter a minute at 12 amps. I built a unit that's producing 240 liters an hour. It uses a bridge rectifier 120 volts. 55 plates 11 amps. He's a link to a Brown's gas generator that explains # plates ,amps and all. http://www.amasci.com/weird/bgf1.html. They talk about using 220 vac. I didn't have enough plate material so I built a 120 vac system. I've got the whole set of plans that do go into more detail about amps,plates and so. Brian
Spewing
Stevie has generated 8 or 9 liters a min using no additives at around 1400 watts. Im sure if you look you will find his work.
