Imhotep-Bedini
Started by Omega_0, June 12, 2008, 12:07:54 PM
guruji
Quote from: freepenguin on April 17, 2009, 12:12:30 PM
How did you test the rewind fan?
I checked the resistance of A: Trigger and Power - both were 139 Ohm. When I hooked up either coil with battery, the fan got magnetized and did not run freely.
I used 1N4001 dioide and TIP102 Transistor today which I bought for another Bedini project. The system wouldn't run at all. :(
I might get the exact components and will try again.
Hi freepenguin sorry that took long to reply but today I saw it. You said fan got magnetized?!! What type are you using than? Mine was with iron core it could not be magnetized. I suggest to try another one. Then use the circuit as shown in the beggining of this forum.
Thanks
tarcius
Hello to all.
So i also started with bedini motor replication.
I have replicated Imothep bedini circuit with 80 mm computer fan.
It worked, fan is rotating and it's giving out about 80 V spikes, depending on position of that potentiometer.
Then it all get very interesting. I try to connect another 120 mm pc fan parallel to the first fan and it partially works,  it  only rotates bigger 120 cm fan when spun by hand.
So i try manualy by hand to spin other smaller one but no luck.
After few minutes of adjusting potentiometer and manual rotating smaller fan it started to spin synced with bigger one
I was getting around 130 V spikes from these two. :)
Now because i dont have osciloscope i connected 200 v 470 uF capacitor to output and i would measure top voltage after some time of charging it.
that way i can see spike height in circuit.
Now one thing to consider, if you have good ears when these fans rotate you can hear high pitch noise coming from them as they rotate. Noise is not constant it pulses with rotation as one short pulse on every revolution of fan blades.
I considered that odd because it did not make that noise if i run these fans on regular power.
Then happened something very interesting.
out of the blue it all stopped working. so i try to spin smaller fan by hand again, and as i spun it i hear that pitch pulses much louder.
When it stopped the pitch noise was constant  no pulsing and i get on output 130 v spikes and either fan was not running!!
Then i scratching my head and wondering what happened. As i was inspecting my circuit i found that one wire that was going from 120 mm  fan is disconnected the one that was going to the potentiometer. It must broke loose because of bad soldering.
If i reconnect it back pitch noise disappear and circuit stops working until i spin larger fan and then it starts pulsing noise and gives out spikes as normal.
If i turn off power to the circuit and disconnect that wire then put power back on it does not start until i turn smaller fan just a little about half revolution. Then it starts that pitch noise and gives out spikes at output.
I think that i managed to get it working in solid state with two computer fans.
If are anyone interested in this i can make video of my setup and offer help to replicate this.
Sry for my english
a.king21
The Bedini device works when stopped because you still have spike bemf producd by the coils. You can measure these without a scope by using ne2 bulbs in series allowing about 80 volts per ne2 bulb. The big question is; do you gate energy from the vacuum? Is there more output than input?
tarcius
Hello
thanks for reply.
Interesting thing is that pitch noise shift as i jently move fan blades.
when i rotate it for about 30 degrees it gives out a little stronger spikes.
I dont have osciloscope but have obtained multimeter that measures frequency.
So this are the specs i have with this circuit:
one wire disconnected as explained in previous post.
with nothing connected at output:
Input voltage: 12V
Potentiometer setting:
Potentiometer range 0-900 ohm
max setting 900 ohm, input current: around 135 mA, output freq around 100 KHz
At min setting 0 ohm circuit draws 184 mA and output has 140 Khz
Info about power supply:
Standard AC to DC utility adapter
model: PLIU-1077
output: 12 VDC 1.25A
Connected capacitor at output 470uF 200V:
potentiometer at max 900 ohm, input current 137 - 134 mA it draws less as cap nears peak value, charged capacitor to 100 V in 31 sec.  Max peak cap value is 112.8 V and gets there in 05m:07s
potentiometer at min 0 ohm, input current 178 -172 mA range because above explanation , charged capacitor to 30V in 9 sec, max peak cap value is 34.1V and gets there in around 11m:00s
After all this tests transistor did not get even warm.
Both fans did not rotatate during above tests.
Repeating above tests but with 4th wire connected.
power supply is the same
connected capacitor at the output is the same
potentiometer at max 900 ohm,  neither fans wont work even when manual moved by hand, to run them on this resistance i firstly must decrease resistance to 300 ohm start larger fan by hand and then run smaller fan by hand, after that i increase resistance to max which is 900 ohm and they work then.
potentiometer at 900 ohm, input current 91-98mA, charged capacitor to 100V in 49s, max peak cap value i 136.1 V and gets there in 11m:50s
potentiometer at 0 ohm, input current is around 180 mA, charged capacitor to 10V in 1m:10s, max peak cap value is 11V and gets  there in 7m:38s
I will do more tests with 80mm fan and 120 mm individualy tomorrow.
a.king21 if you have some ideas how to check for unity or overunity please tell me.
a.king21
Without seeing your circuit it is impossible to comment - except generally.
The main problem with radiant energy is leakage. The electric field exists outside the wires for the most part.( Steinmetz).  Kapanadze gets round this problem with heavy anti-static insulation.
This leakage feature makes it virtually impossible to loop. Kapanadze uses polystyrene, perspex and epoxy resin shielding in all his visible builds.
The best result I have got is charging 2 separate batteries and doing a swop. There has been an energy gain but only very slight.
I am currently experimenting with a Bedini-Cole motor, which seems to work, but it's early days yet.
Also remember your batteries need a rest period or they will fail.
