Poor mans EFIE?
Started by sportcoupe, June 13, 2008, 05:17:06 PM
sportcoupe
I found this alternative, cheap and easy to make circuit to alter the O2 sensor signal compared to a full EFIE device. It was buried in chapter10.pdf, I cannot find any more information on it. Can anyone provide feedback on it?
"An alternative: As the signal coming from the oxygen sensor to the vehicle?s ECU fuel computer needs to be raised slightly to allow for the much cleaner exhaust produced when a booster is being used, an alternative solution has been suggested and tested. The idea is to add a small, adjustable voltage to the signal already coming from the oxygen sensor. This voltage can be from a single ?dry-cell? battery and adjusted with a variable resistor.
The circuit shown here allows a voltage anywhere from zero to 0.5 volts to be added to the oxygen sensor signal. This must not be done unless a booster is running. Using it without a booster is liable to lead to engine overheating and possible valve damage. This, of course, applies to the previous oxygen sensor signal adjusting circuit as well."
sportcoupe
Judging by no responses I assume no one has used this circuit to adjust their O2 sensor. I assume this is because this cheap circuit does not work.
atlantex
If the circute is functioning as described, then it will work in a car but leaner fuel will head up the whole engine, so you have to use
a additional cooling option, like a water bubbler.
you can read some basics about cheating the lambda-carcomputer system
http://better-mileage.com/memberadx.html
atlantex
lapperll
I also found a O2 altering devise similar to the one you have posted.  The Mad Scientist HHO Research has a series of three videos on U-Tube where he builds and tests the unit. I haven't tried to build one yet, but it seams like it works.
Hope this helps,
http://www.youtube.com/watch?v=jgHJDD6UK0A
Lapperll
innovation_station
i just built this and it does what it is suspoto  8)
i have not installed it yet tho
ist
