Thanks to ALL for your help!!
fully baked innovation
Started by ring_theory, September 24, 2005, 07:31:06 AM
ring_theory
cwstang
Bell Labs back in the 50's invented a similar device, however it was used as a memory device (long before todays solid state cache) using wires through a torroidal magnet.  They would run electricity through the middle of the torroid and the magnet would magnetize one way or the other depending upon which way the current ran and also had a "read" set of wires through the middle to determine the magnetic direction of the magnet.  Hence 0 or 1.
These "bits" as they were known then, were the "memory core" components of the #1 ESS telephone switching computer that came out in the late 60's.
You can find them in some museums if you know what you're looking at.
ring_theory
Low-Q
Your invention is fully baked, but does it work - or will it ever work? I have tried similar device as you have but I had much more magnets in the toroid. I used card board to separate the magnet in a way that they formed a circle - so the magnets touched each other in the inner part of the circle. I used a Cola bottle as support while setting up all the magnets. The device did not work, but the reason is that regardless of how I configured those magnets, the sum of all magnetic fields ended up in zero, hence no possibility to make any power out of it.
The origin of my idea then was when I in fact generated 100% clean CD current out of a regular toroid transformer by moving a neodum bar along the vindings. I then tried to supply the toroid with DC current and leave the magnets on a rotating rod, and the magnets start to move in circle around the toroid transformer - i short, this was a brushless DC motor without any complex power regulator.
So I tried to replace the toroid transformer with permanent magnets as described above - and that did not work. It should be the same thing as using the toroid transformer as a DC electro magnet, but no.
Br.
Vidar
