IST HHOOKA!st compleat plans every piece
Started by innovation_station, June 24, 2008, 12:28:19 PM
innovation_station
on the way  pictures included
;D ;D ;D
making this world a better place 1 soul at a time ....
ist
innovation_station
im just finishing the controler for the dubble cell  unit
cell 1 is for gas production dirrectly fed to the air intake and cell #2 will use the hot water from cell 1 and burn it off ;) never to return it will be a vaccume cell fed into the pvc and vaccume system the controller is able to turn off both cells at will and moninotor the amparage between both cells there 2 30 amp curcuit breakers in it and 4 relays 3 switches and an amp meter
a kool system the vaccume cell should make a big diffrence ...
ist
innovation_station
Jokker
Seems it is going somewhere  ::)
Keep it up  ;D
Buy the ticket !
Take the ride !
innovation_station
the can and the cell notice how i put the 4 ga wires through the can so the heat from the connections does not melt the can ....
that is important  i used a 3/8 drill bit with the 4 ga car audio wire it makes a tight seal and does not leak even under high heat and some pressure  ;D
simple i used a brass fitting in the cap so it can take a bunch of heat and does not leak the can works great
but the cap must have an o ring to seal it DO NOT USE THE NYLON cap seal they suck  ;)
so next is my cell
ist
