I tried to rebiuld a Don Smith Device
Started by GM, September 25, 2005, 04:19:40 PM
Google
@jimboot,
Please watch and comment on JLN video I posted and the scope measured COP of 1900/1150.
Best,
Farmhand
Quote from: Google on March 17, 2014, 01:35:56 AM
Here are the video shots of input and output.
Best,
In my honest opinion, and going by my own experience with energy meters, I can say they do not read the input to some devices correctly especially HF devices which cause noise on the supply lines, it glitches the meters due to the transients I think. I placed an energy meter to measure the input to my Big Tesla coil without any line filters between the meter and the MOT supply circuit, it told me all kinds of stuff, then it died, an extreme example, however after using two line filters and Power Factor correcting the MOT's and ensuring there was no sparking to the circuit ground by the spark gap, I get stable and accurate readings from different energy meters, they tell me it runs with a PF or over 0.90.
And the input is coherent with the calculated input. Whereas before I took the above measures to minimize the Noise on the lines the meter always showed smaller than actual input values, due I guess to computation errors as a result of the electrical noise on the supply lines.
I can only say that if it were OU it would be lighting up the internet by now. My guess is the actual input is different to the measured input by the energy meter or the calculated output are incorrect. AC power measurement can be complex, especially when dealing with non sinusoidal wave forms. Meters have flaws. The input and output would need to be determined by a thorough power analysis.
I would be more inclined to believe the input measured is correct if he showed that he has line filters between the energy meter and the Device Under Test.
Cheers
Google
@farmhand, Jln is another disinpho agent, in tom a$$h0l3 beardens meg also jln showed overunity.
Farmhand, am asking you in specific now. What if we place 5 bifilar pancake coils over the cooktop ? All powering their own 1000 watt loads. And we set the input of cooktop to 1000 watts.
Can you please throw some light on this. My @$$ is itching badly to buy a cooktop and make 5 bifi pacakes, but before I invest time and resources in it, I want to be doubly sure of what I am doing.
Best,
forest
My response : if Google , "do you think that you can build home using Sunlight ?" I think you would agree :  That's the kind of statements being totally b*it....,right ?? OR
Somebody said something he cound't say openly ?
How about building home using laser to cut wood fast and precise ? More convincing, right ?
That's the same about Don Smith statements. I beleive he was in contact with group having real OU devices, so please consider that he said very indirect tips.
Jimboot
Hi Google - saying that makes me giggle - as I own an SEO Company.
This is from one of Laurent's vids - its all in French but description (below) is in English https://www.youtube.com/watch?v=SSqHwMabmmw
Hi all[/font]Sorry but this time i made the video in french.I explain in the video that i testeds the vGEGENE with a lot of different secondary coils, and when i tested the small 12 cm diameter coils that are intended for my small induction plate GEGENE , but on on my big Tristar induction plate, i got powerfull result also.So a pancake coil of a smaller diameter than the induction coil seems to work very well. And wonder why ??So i scratch my head and i made this theory proposal, which is only my affabulation good or not , but i dare to present here to you.Would it be possible , that we get an analogy between airflow That i know quite well ) and the flux of a magnetic field.So the idea would be that ,:First , we put the secondary coil outer diameter, smaller than the outer diameter of the induction coil and the secondary inner diameter larger than the inner diameter of the induction coil,so we get a part of the induction coil (outer and inner ) free to produce a magnetic field which is not submitted to Lenz law , because it suffer no charge at all and is for that reason very free and light to alternate with great speed because no work to do.And in the same time , the flux in the middle of the induction coil, is working hard , battling in the pancake secondary against Lenz and his army, to produce power to animate the load. And the idea is , as per analogy to aerodynamic would it be possible that those "FREE lenz " outboard magnetic field coul help the working one to do the job easier ????=?OK please forgive me , but this is the beginning of a very hard year and we have to try to think more trhan usual , OUT OF THE BOXGood luck at alllaurent
