URGENT! WATER AS FUEL DISCOVERY FOR EVERYONE TO SHARE
Started by gotoluc, June 26, 2008, 06:01:38 PM
0 Members and 56 Guests are viewing this topic.
allcanadian
@Gotoluc
QuoteThank you allcanadian for your time and explanation of what is going on in this circuit.
Would you know what the purpose of d, C , B , A and L (as circled below) are doing in this circuit
(ab) are contact brushes
(c) copper contact ring-closes circuit
(d) insulators
(C) is a piston rod
(B) is a piston
(L) is a HV igniter electrode
The questions one should ask are what exactly is ignited? where are the intake/exhaust valves?----it seems there is no means whatsoever for anything to enter or exit the sealed chamber?
If I have any advice to give I would recommend ignoring what you "see" and concentrate on the qualities of the components, what is there function? How do they apply in the circuit? How does this circuit relate to the one you posted?
Grumpy
Quote from: allcanadian on August 12, 2008, 10:54:35 AM
@GrumpyI think you know as well as I do that a good patent lawyer will protect the spirit of an invention while giving very little in the way of understaning to the layman nor those "skilled in the art". If you look at the patent you will find a self inductance coil H charging a capacitor, the capacitor is then discharged through the short primary of a step-up transformer. This is Teslas "method of conversion" and you will see it in more than a few of Teslas patents if you know what to look for. If this is indeed just another ignition transformer why use the self inductance coil H -- it is not needed.
As well if we look at Gotoluc and quimans circuits you will find a "resilient" media in the circuit in the form of both a capacitor and the blocking diodes. The HV section of the ignition coil will see the low potential path to the capacitor and move towards it then the diodes slam closed producing a high potential short wave period shock wave on the capacitor, the capacitor then discharges through the only other route----the spark gap. Here we can use a simple analogy---- strike a drum and hold the striker on the drum (DC current)and there are very few oscillations, but if we strike the drum and quickly remove the striker the oscillations will continue. In my experiments with gotoluc's circuit I have produced discharges having qualities I have never seen before, the discharge is a brilliant white with a volume and length many times greater than the capacitor itself could ever seem to produce. The question I think we should be asking is what process has changed the qualities of the discharge and how can we improve this process?.
LOL!  Just coaxing you to say it out loud, Allcanadian.
The little thing that no one ever seems to notice is that the hv is biased above zero in these devices.  Increase the bias - increase the effect.
On this page is are some interesting comments made by Tesla when he was about 60 years of age and had accomplished many things - about 3/4 of the way down the page:
http://www.tfcbooks.com/tesla/nt_on_ac.htm
Counsel
I understood a little while ago when you made the statement of using several thousand horsepower put into a condenser, you could take out of the condenser a million horsepower.  I wondered if you got the same condition with this machine.
Tesla
Yes; I charged the condenser with 40,000 volts.  When it was charged full, I discharged it suddenly, through a short circuit which gave me a very rapid rate of oscillation.  Let us suppose that I had stored in the condenser 10 watts.  Then, for such a wave there is a flux of energy of (4 x 104)2, and this is multiplied by the frequency of 100,000.  You see, it may go into thousands or millions of horsepower.
Counsel
What I wanted to get at was, did that depend upon the suddenness of the discharge?
Tesla
Yes.  It is merely the electrical analogue of a pile driver or a hammer.  You accumulate energy through a long distance and then you deliver it with a tremendous suddenness.  The distance through which the mass moves is small?the pressure immense.
Counsel
Did you find that that was the best condition for transmitting energy without the use of wire?
Tesla
No, I did not use that method when I was transmitting energy.  I used it only in the production of those freaks for which I have been called a magician.  If I had used merely undamped waves, I would have been an ordinary electrician like everybody else.
The pile-driver is a reference to unidirectional impulses.
        -Frank Edwards
SPP-48
@allcanadian
@Grumpy
Thanks for your input guys. I would like to try this Tesla patent.
Attached is my translation into a circuit for testing.
Any suggestions for component values would be appreciated.
Cheers
Sam
Grumpy
Well, acording to the patent, the inductor is charged on the first contact make, and then the capacitor is discharged on the second contact break.
Just use a cap that can handle the inductor discharge which depends on the inductor.
        -Frank Edwards
