URGENT! WATER AS FUEL DISCOVERY FOR EVERYONE TO SHARE
Started by gotoluc, June 26, 2008, 06:01:38 PM
0 Members and 40 Guests are viewing this topic.
bumfuzzled
Quote from: gotoluc on August 14, 2008, 12:34:58 PM
kalnai, I don't have that information wet!... but I do have on order the most powerful coil that MSD makes and once I receive that and do some tests I should have some numbers if it works with that coil. Krupa has said it needs a high performance coil. If others want to work on this here is the link to the coil I got, which is at a good price if you consider the free delivery to the US.
Link: http://projectmotorsport.com/store/product.php?productid=319&cat=0&page=1
Here is what MSD says about this coil: When the mad scientists at MSD were creating this 7-series ignition coil they pulled all of the good stuff out of their Pro-mag 44 coil and stuffed it into this one. The HVC-2 Coil produces 48,000 volts at a stout 2-amps with only .016 ohms of primary resistance! It utilizes an iron U-Core design with a segmented bobbin molded from Rynite and wound specifically for incredible voltage capabilities, lightning quick rise time and lengthy spark duration. The Rynite housing features far spaced brass primary terminals and a well protected secondary tower for increased spark isolation.
We shall see
Luc
I was basically laughed at when I mentioned this coil several weeks ago.  :-\
gotoluc
Quote from: bumfuzzled on August 16, 2008, 07:41:34 AM
Hi bumfuzzled, yes I'm sorry that happen to you at that time.
The reason I got this coil is to test the Krupa style plug but I'm not sure how well this coil will preform without its driver. It will be at least one more week before I receive it.
Stay tuned
Luc
gotoluc
Yucca
