URGENT! WATER AS FUEL DISCOVERY FOR EVERYONE TO SHARE
Started by gotoluc, June 26, 2008, 06:01:38 PM
0 Members and 25 Guests are viewing this topic.
gotoluc
Quote from: -[marco]- on August 23, 2008, 09:17:57 AM
Okay so i was trying to see the effect when using vacuum tubes and all the meters go funky.
I charged a 470u to 500 volts and discharged it thrue my hand...
M.
My God Marco :o... are you okay ???... I thought that was enough to kill someone.
Please let us know if you will be alright :'(
Luc
unity2zero
Luc
Durability tested your simple circuit design with the spark plug. I have it automatically run with a continuous synchronous water atomizing spray on it. It works well until about an hour later when the switching relay started to give way. Think should have an electronic switching circuit to take over this.
unity2zero
turbo
Quote from: gotoluc on August 23, 2008, 10:37:32 AM
Luc
Men it really hurt and my body was shaking for two hours.
But i will be fine.  :)
I tried some high voltage vacuum tube rectifiers like the dy86 ,pd510 and the gy501 which can handle 18-25KV but they do have a warning on then for emitting X-rays so i held the geiger counter nearby.
The gy501 was the one that came best out of the test the heater only needs like 3 volts so i hooked it up to some battery's.
The dy86 burned out for some reason and it did not function long.
Anyway it all worked much better then using Silicon diodes which i was doing like half of the day.
I did not use any timing device i just placed a capacitor on the relay coil and switched the coil in series with it's own breaking contact , which works fine.
By varying the value of the capacitor the switch rate increases or decreases.
Also i did not use any mains or an inverter i just pulsed a simple 12 to 200v transformer from the battery which also works fine.
Marco.
gourdman
Hello everyone,
  Nice work.
   I found this forum thread about 3 days ago while trying to find some hydrogen fuel information.
   I've read every page of it. its remarkable what you have discovered.
   I,m gathering the parts to build the circuit now . I hope to have it working this evening.
   I,m no where near as knowledgeable as many of you here but I am willing to help any way I can.
   I do have a few Ideas but I"m just trying to get up to speed with you guys right now.
   Good luck and be safe.  Will post again when I get my circuit up and running.
      gourdman
gotoluc
Quote from: unity2zero on August 23, 2008, 12:02:51 PM
Luc
unity2zero
Hi unity2zero, thanks for sharing :D... you are correct!... the relay is not going to last. I have been asking for help on a solid state circuit since my electronic knowledge is very limited. Hopefully we will find a simple circuit that most could build to replace the relay. Once we find that it will be shared. If anyone would like to share (a simple circuit) that would do what a SPDT switch does please help. I started a topic for that here: http://www.overunity.com/index.php/topic,5438.msg122872.html
Check what was suggested and if you know of a even simpler way please do share your circuit.
Thanks
Luc
