URGENT! WATER AS FUEL DISCOVERY FOR EVERYONE TO SHARE
Started by gotoluc, June 26, 2008, 06:01:38 PM
zzzz
Hi Greg,
    About Cap, long time ago, i have experiences with Vacum Tube class A sterio amplifier, at final out put, they must have VERY PRECISE CAP to block DC come out to destroy speaker, that So Expensive :( (on that time, wima brand ), some guy recommmend to modify standard cap to be very good cap, Bi-Cap, it very popular trick may be you already know.
   just use very small cap ( polystylrin or polypropyline type non polar, picofarad value) parallel to main cap, they said sound stage will far more dynamic, not the same as very expensive cap, but from my ears, i can here a lot differences from standard, they call this modification Bi-Cap.
  This may work, i don't know, I not have theory.
   cuz I'm mechanic  :P   ;D
http://www.thlaudio.com/wimaitme.htm
zzz
rfsimoes
Hi all,
Yesterday I ran my engine on gasoline and plasma for some stable and reliable minutes.
The experience was so encouraging that today I decided to go ahead with water alone but it was a no go.
I puled and puled that cord and nothing.
I could only hear a loud bang at the exhaust but no power stroke. :'(
Sadly
rfsimoes
rfsimoes
plasmastudent77
Sitting here having a think it would appear that you have a vacuum created due to very high current flow then a rapid current collapse of the plasma - and at the moment of collapse drawing the normally untapped ZPE energy out of the vacuum - and as such ZPE being literally tapped into by the current collapse. In fact, I theorises that the plasma collapse is a ZPE "switch" that may expalin why under "orthodox" electronics theory that its impossible to create more energy - unless of course you are tapping into the ZPE field using the plasma collapse. And tapping of the ZPE is possible in a vacuum but requires I believe a voltage potential to first exist across the vacuum ( where the plasma used to be ) - which is what you would have immediately after the plasma collapse across the plug spark gap.
This is the "Wokka Theory".   :)
kewlhead
Quote from: gotoluc on October 07, 2008, 02:23:04 AM
Hi Greg,
I've got about 6 or 8 photo flash caps from a box of disposable cameras my uncle gave me. They are 330vdc and about 160uf. I tried them and they work well. He picked up those cameras for free from some photo shops (after they remove the film to develop)
That's about all I know
Luc
PS @everyone, I have not been posting as much since I'm doing many tests on a very interesting circuit to which I hope to share soon.
looking forward to it   Good Luc !
sparks
Quote from: rfsimoes on October 07, 2008, 03:50:37 PM
Hi all,
Sadly
rfsimoes
    Maybe you could try injecting propane to get her started and heated then shift over to water.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
