URGENT! WATER AS FUEL DISCOVERY FOR EVERYONE TO SHARE
Started by gotoluc, June 26, 2008, 06:01:38 PM
zzzz
Thanks Greg
   Now i understand
  yesterday I went to three electronic shops , all i got is not satify again,  >:(
I got 350mA 12000V diode only 5 ea ( VexUs circuit is 15000V)
(I use the same Bosch blue coil as your)
Cap 470uf but 250V biggest that they have only 2 ea
Cap 22uf 400 V 5 ea thats OK
i add 10uf 450 V
R 220 ohm 20 w  8 ea
but they don't have isolation transformer, even 220 to 110 V they don't
they have only theroide 220-45V minimum ratio that they have... :P
I live in Thailand but not in capital...
maybe this is the time to visit Bangkok...
12000V BreakDown. is enough for this coil  ???
will have any problem if i don't use isolation trans. ???
happyvalley808
Quote from: zzzz on October 09, 2008, 10:08:38 PM
Thanks Greg
   Now i understand
i add 10uf 450 V
R 220 ohm 20 w  8 ea
Hi zzzz,
Check out Futerlec.com thet are based in Bangkok i believe...
Regards,
HV
kinesisfilms
someone else has successfully done this.....i got these images through a yahoo group
bwb
To LapperLL and all.
Hey lapperll -- I have tried every setup I could think of since that other post and still think it is the type of inverter. I am using a modify sine way inverter. The original plasma by sr1 used two batteries and I think a modify sine way.I believe but don't take my word on it that you could run the inverter though a  isolation transformer which is used to decouple two circuits then to the nexus circuit.At least that is what I will be trying when I can locate or make one.
I have to say that Bill's circuit is worth the trouble. I bench tested it both with a points distributor and a electronic ignition system(magnetic pickup distributor)firing eight spark plugs and it worked perfect. I ran it for about 20 minutes with the electronic ignition and then shut it down and discharge the cap for safety and found no heating of anything just like Bill said. I even eliminated the mot and just used a small 110V 50 to 60 HZ coil with out a core and it worked fine.I used telephone line wire for all the leads,But will use a bigger gauge wire for the finish product.While it was running I spray a water mist on the plugs and got the normal response.(POW )Water exploding. :o All eight plugs exploding water made me take a step back.  ;D
But in the mean time I will contact Bill and see what kind of inverter he is using? A modify sine way or a pure sine way and post what he has to say about it.
Bill's new video
http://video.google.com/videoplay?docid=-6829539099631634836&hl=en
