URGENT! WATER AS FUEL DISCOVERY FOR EVERYONE TO SHARE
Started by gotoluc, June 26, 2008, 06:01:38 PM
happyvalley808
Hi Greg,
I plan to build your "VexUs" circuit, but i will use a voltage doubler in place of the FWB....
In your opinion should i increase the value of R1 or would it be sufficient for testing...
Thanks.
HV
gmeast
Quote from: happyvalley808 on October 12, 2008, 12:06:10 AM
Hi Greg,
Thanks.
HV
Hi,
What size your CDI Cap (C1) and R1 now?  You'll need to make sure your doubler can deliver the CDI charge current to C1 through R1.  The FWB has no current limitation up to 'burnout'. (smoke).  As the double increases voltage it also decreases current so it's possible that C1 won't charge fast enough ... it might 'float and arc' at the plug.
I have no experience with rating doubler ladders ... sorry.  Can someone advise here please?
Peace,
Greg
Greg
alan
If you put a bifilar coil on the HV coil you've got a VIC with minimal amps,, whci hdrives Stans injectors. (I think)
dllabarre
Quote from: alan on October 13, 2008, 09:13:11 AM
Except, to efficently fracture water into Hydrogen and Oxygen you need to supply pulsed DC to the fuel cell.
If you can figure out a circuit to pulse this HV let me know.
I'd love to test it with my fuel cell.
DonL
sparks
    Meyer produced his plazma by injecting an ion stream along with his water.
The water was changed into hho gas as it was partially electrolysized passing through the nozzle which was set up as a capacitor in a series resonant circuit.  Plazma has an extremely energetic flow of electrons around a grouping of ionized atoms.  Instead of electron energy expressing itself in a field measured in protonic diameters it now is travelling around billions of neuclei grouped or held together by their magnetic dipole moments.  You got yourself plazma.  The electron kinetic energy is now emitting highly energetic displacement waves that are absorbed by the hho gas nitrogen and oxygen mixture.  This energy input causes the water to explode.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
