URGENT! WATER AS FUEL DISCOVERY FOR EVERYONE TO SHARE
Started by gotoluc, June 26, 2008, 06:01:38 PM
0 Members and 81 Guests are viewing this topic.
cell1
Probably you already now this link:
http://www.rexresearch.com/meyerhy/2067735.htm
I found interesting that is specifying about how highest level is the voltage into injector.
Someone asked about the inductance of microwave oven transformer:
Primary: 286mH, resistance 1.9ohm
Secondary: 36H, resistance 160ohm
It is for 220V a.c.
Best regards,
Cell1.
insane4evr
Hi Greg,
Thanks for the circuit update.
I have a comment not on the R1 placement but the CDI cap ground. My thinking is that when the CDI discharges, the discharge current path is from the plug center electrode, thru the NTE517 diode, thru the CDI cap, thru the junction of (the storage cap +, CDI cap + and if present top end of wire), thru wire, thru wire ground connection to vehicle frame/engine block, thru engine block, thru the plug threaded body thru the plasma spark. Whew. ( Not sure of direction of electron/curent flow convention, I was just tracing the path.)
So, those making this should make sure there is a good current path from the CDI + back to the plug threaded body. That is, all ground connections should be good and solid.
gmeast
Quote from: insane4evr on October 18, 2008, 04:05:56 PM
Hi Greg,
Hi insane4evr,
You're good!  So you went through that too, huh?  Dizzying!  Simple circuit ... complex path.  You're the only one that has analyzed this properly AND stressed the need for GOOD connections.  An isolation transformer is helpful.
Greg
happyvalley808
@Gmeast,
Did you see the link for the isolation transformers?  120v in 120v out 120w for $16.00 , Unfortunetly they only ship in the US.
Let me know what you think...
Thanks,
HV
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWAX:IT&item=120132004551
gmeast
Quote from: happyvalley808 on October 18, 2008, 08:11:37 PM
@Gmeast,
Thanks,
HV
Thank you HV!
I will buy one and test it.  It looks friendly and the price is right.  There's gotta be a way around their problem with shipping elsewhere.
Thanks again,
Greg
