URGENT! WATER AS FUEL DISCOVERY FOR EVERYONE TO SHARE
Started by gotoluc, June 26, 2008, 06:01:38 PM
sparks
    I have modified generators in the past too run on propane.  There are a number of adjustments to be made to the engine.  Timing issues and valve lubrication systems which basically boil down to dropping light weight oil in the intake manifold.
    I believe that the popping heard when the water is misted onto the plasma stream is not hydrogen and oxygen exploding.  What is happening is that the plasma acts like a static discharge that lasts for a long long time.  This discharge breaks the water molecule to molecule bonds.  And the water becomes h20gaseous.  Steam.  It will revert to water very quickly as there is no thermal agitation of the water molecules like in a boiler.  To increase the pop it may be necessary to ionize the intake air so that the whole mix is electrically active.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
gotoluc
Quote from: plasmastudent77 on November 08, 2008, 03:53:24 AM
Hi guys
I have had success getting a fuel vapour sytsem to work. Its not related to this topic, but I'm hoping that maybe Luc might find it intersting with his GEET work.
My topic   http://www.overunity.com/index.php?topic=6007.new#new
Cheers
PS77
Thanks plasmastudent77 for doing these tests and starting this topic. I did post in your topic and wish you the best.
Thank for sharing.
Luc
gotoluc
Quote from: grahamsa on November 08, 2008, 09:24:52 AM
HI all
im new, all the way from south africa. very interested in the plasma spark tech. i have a feeling it is the way forward :)
i have a few questions:
1. it was posted earlier that, running a 30:1 mix and a proper atomisation method, not a carb or injection, would work well and not generate too much heat. WHAT is the correct fuel induction method to use?
2. can the plasma circuitry be used on a modern motor (with out a conventional coil, dizzy setup)?
3. for best results, should the plasma spark be run with a lean petrol mix with water injection and a hho generator?
4. if so what is the best method of water mist injection?
i realize these may be simply questions, but answers will greatly increase my understanding of the tech, as well as give me an idea of the long term goal.
many thanks!
Hi grahamsa and welcome to this topic.
You have some good questions there and I wish I had the answers to them but we have not wet found the best and most efficient ways. We are only starting to look at these. The 30:1 ratio test was done by Robert Krupa who is independently working on developing his Firestorm Plasma plug for marketing. So the full details of his work are not publicly shared as we are sharing here.
We will get there but the time will depend on public open forum participation.
Luc
gotoluc
Quote from: sparks on November 08, 2008, 10:08:28 AM
Hi sparks,
thanks for your input. I really like this idea: To increase the pop it may be necessary to ionize the intake air so that the whole mix is electrically active.
thanks for sharing.
Luc
Damianos
Quote from: gmeast on November 07, 2008, 08:45:04 PM
Hi Damianos,
Super name you have there.  Great job man.
Peace,
Greg
Hi Greg,
First of all I have to thank you for your good words and for your very very useful help.
I will not stop here, I will  keep on working...
Thank you again my friend.
Damianos
I don't know... I like to learn...
