URGENT! WATER AS FUEL DISCOVERY FOR EVERYONE TO SHARE
Started by gotoluc, June 26, 2008, 06:01:38 PM
0 Members and 81 Guests are viewing this topic.
plasmastudent77
Hi All,
An update on using different fuels ( including 40% water /ethanol mix ) over on my fuel vapourizer thread:
http://www.overunity.com/index.php?topic=6007.msg137413#msg137413
Cheers
PS77
gotoluc
Quote from: gourdman on November 11, 2008, 02:50:38 PM
I was able to get the plasma spark working today . When running the engine under normal operation
there seemed to be a slight increase in power when i turn the Plasma spark on. When I got the Geet system running really well on about 75% water 25% Gasoline 5%oil. I turned the plasma spark on and it bogged down. I am convinced that the plasma spark is making the fuel combust so fast that I need to retard the timing.
  Which is what I have been told many times. It seems to me it would be easier to build some sort of bracket to adjust the magneto, instead of some of the other Ideas I've heard.
Thanks again to everyone for the help and advice.
       Gourdman :)
Thanks Gourdman for the update. I sure hope you are right about advancing the timing since this will be Excellent news.
Thanks for sharing.
Luc
gourdman
Hey guys.
Cowboy I have been injecting the HHO into the air intake but I think It maybe better to put it into the Geet fuel bubbler. After I run the engine awhile I have to shut the fresh air intake almost all the way off and pull most of the air through the reactor to keep it running good. The pulley I rigged up for the alternator slung the key out so I've been redoing that today.Hope to have it running again tomarrow.
   I should inform the group that is trying to emulsifier Browns gas that this engine is mixing the fuel so well it takes a long time to separate.The water turns to pudding and traps alto of air. I'm sure it will trap some HHO if I start injecting it before the geet tank.
  At Luc : I'm almost sure the plasma spark is causing the engine to stall because it's making the fuel burn faster. It's the only thing that makes sense. Because the engine seems to runs better in normal operation with the plasma spark.
I left the carburetor on the engine and just sealed the air breather and put a shut off valve on the fuel tank so I can compare normal running to the Geet system easy.It makes getting it started easier too.
Just wish I could retard the timing as easy.
Thanks all    Gourdman  :)
gotoluc
Quote from: gourdman on November 11, 2008, 09:33:34 PM
Hi Gourdman, you probably can retard the timing. Your engine timing is most lightly fixed by a flywheel magneto coil ignition system. What you can do is remove your flywheel bolt and remove the key that locks the wheel at that timing position and retard the flywheel position and tighten the bolt good and it should stay fixed. Maybe before you do this set the piston to TDC and make a mark on the flywheel and engine so you have a reference point in case you need to move it in different positions.
Thanks for sharing
Luc
happyvalley808
@All,
I was reviewing  Ash's video production of everyone's progress and i caught something Stan Meyer say's, ( go to 12:10 sec. on the video) , he says you replace the spark plug with a "water fuel cell injector" Simply feed processed water to the injector ?? ......i believe that there is two reasons Stan meyers needed to use resonance frequency in his water fuel cell, #1- to produce an efficient supply of hydroxy ......#2- using resonance frequency's no catalyst is needed in the water , I think he may have been injecting hydroxy enriched water .... Super charged  with lots of hydroxy trapped in the water...   A simple float activated fill valve could refill the water fuel cell as the water is used.....Stan did have a metal holding tank on his dune buggy.....??
For about 2 months I've been toying with the idea of using the water pumped straight from a water fuel cell to power a small engine, now after hearing Stan say it  i believe this may work.......
Please everyone let me know your thoughts....
Aloha,
Jared
http://video.google.com/videoplay?docid=-9071695126208320206&hl=en
