URGENT! WATER AS FUEL DISCOVERY FOR EVERYONE TO SHARE
Started by gotoluc, June 26, 2008, 06:01:38 PM
alpeko
For gmeast,
Thank you for posting oscilator circuit.In my country standard for mains voltage is 220V/50Hz.
I want use 2x12V/220V~ transformer.How much power is enough for transformer in VA.Did you measure curent and total power.My idea is : increase secundar voltage to 250 - 300 V,because I have possibility for wind new transformer.I not planing use voltage multiplier.
Thank you
Alpeko.
gmeast
Quote from: alpeko on February 23, 2009, 04:38:37 PM
For gmeast,
Thank you
Alpeko.
Hi Alpeko,
The PF 24-10 is a 24VA transformer ... so what you are planning should work well I think. However, the oscillator's frequency of operation will still depend on testing various capacitors to hit a target frequency .. whatever you choose, but I would still try to keep it between 60 and 100 Hz ... my feeling.
Greg
alpeko
For gmeast,
Thank you very much for info about transformer.On Panacea I see diferent inverter power.My opinion is that 50W is enough for CDI plasma.When I testing " pigybacked" hybrid plasma,my spark gap is only 1-2mm with Bosch ignition coil.When I testing CDI only,4.7 uF cap charged on 350 V and discharged on coil, spark is much bigger,about 10 -12 mm.And plasma efect is better.I must reverse HV diodes (35 pcs of 1N5408) in this mode.With or without protecting diodes, spark is 10 mm.With join diodes plasma efect starting.When I testing stock ignition,only negative voltage produce spark and plasma.ON this mode I must reverse polarity of cap and HV diodes.Spark gap or spark is only 1-2 mm.In both tests is same cap 4.7uF/400V electrolytic.What you think about high voltage diferences ?
Thank you.
Alpeko
gmeast
Quote from: alpeko on February 24, 2009, 05:31:46 AM
For gmeast,
Thank you.
Alpeko
HiAlpeko,
You are in the 'smart range' for your Cap size and voltage ... 1uF - 4uF for 300 - 500 VDC.  As far as changing all of the polarities around, it makes it a different circuit for the piggyback version.  Sounds much like the Nexus now ... see Sky Hero' Nexus circuit for that.  I only have worked with my VexUs circuit and gotoluc's original CDI version of the Water Spark Plug... no cross-talk issues.
Greg
alpeko
Hi gmeast,
Yes, in modern cd ignition system is 1uF capacitor,and 300-500 Volts.But my target is working plasma.
For this I want testing diferent circuits.In this moment I don't know which system is the best.Yours experiences and others who build and test plasma spark is very valuable for me.
Thank you again Greg.
Alpeko
