URGENT! WATER AS FUEL DISCOVERY FOR EVERYONE TO SHARE
Started by gotoluc, June 26, 2008, 06:01:38 PM
HaroldCR
Damn Greg
Sad to read your last post. I have followed every post on this forum with your project.
  My wife's Son is a mechanic down here, and, I am trying to get him to understand your project and rig up a system on his car. I believe he can get a nice bit of income helping others down here.
  Is there a way to stay in contact, in case I need to ask a question or two ???
  I am on a fixed income and had hoped to help with donations to these researchers, but, things are bad down here, and the Govt. is allowing rates to go up, in this recession ???  How the hell people are supposed to live, is a real problem. However, extermination is what the powers to be are looking for. It's ALL greed, except for fine folks like you and the others that post all their projects on these forums.
  Thank You for sharing your project, and, good luck in the future.  Harold in Costa Rica
gmeast
Quote from: HaroldCR on May 15, 2009, 01:45:05 PM
Damn Greg
Hi Harold,
Thanks for your comments.  Yes, our government (US) has only one use for productive US citizens now and that is to finance the new world order.  Population reduction is actually the main goal.  Extermination is a real prospect.  Obama's recent $75billion deal to homeowners to buy down upside down mortgages has a catch ... it's a taxable event.  If your mortgage is adjusted down ... let's say $50,000, they let the IRS count that $50,000 as income to you.  I think the first amendment is still in force but just to keep it safe I won't say what I really think of Obama, his thugs and the speaker.
I'll scan the the groups for as long as I still have a connection.  I wish I could find a bunch of people around here to get together, find a plot of land, put up a couple of metal buildings, pool resources fund with some regular jobs of course but also facilitate some of these research projects.  The independent researcher will not see one cent of Obama's $billions earmarked for energy independence ...only the huge multinational energy companies will see that money ... and it will be from lobbying, political influence and every other form of corruption that is contrary to what made America and Americans great in the first place.
Greg
tony b
Hi all.
This is all so exciting! Some of my perhaps "off the wall" comments and ideas on this subject.
It's with great interest that I've gone through all the posts, viewed all the YouTube videos both related to plasma spark and water for fuel experiments.  From my observations, it appears plasma spark ignition does appear to explode mists of water, with a "direct burn" of the hydrogen (?) in the water negating the need for electrolysis first.
The main problem appears to be delivery of  water in a highly enough atomized state to burn well, something clearly not possible by misting water into a carburetor or utilizing a regular fuel injection system that only runs at system pressures of about 40-60 psi.
It seems that the "ideal" would be the fuel system of a direct injection engine running at 510-1740 psi. Would this not be better suited for atomizing water to almost a molecular level in trying to run an engine on water?  The arc of the plasma ignition may then ignite/burn the water mixture with little problem.  http://www.worldcarfans.com/2060518.001/2008-gm-36-liter-vvt-engine-with-direct-injection
Clearly there would be experimentation needed on ranges of timing, different designs for injectors, and perhaps increasing the engine's compression ratios and so on, to determine the optimal combination to make this work - if at all possible - but it's a start.
I think I also came across someone's calculations that hydrogen has 3 times the energy of gasoline (?) per volume.  If this is so, then the engine's computer could be tuned to regulate fuel flow to 35% of that of gasoline for the equivalent power, with subsequent tuning either increasing a vehicle's range of travel or power output.
In either case, the only thing coming out of the tailpipe is water vapor!!  ;D
555
Quote from: alpeko on May 08, 2009, 04:02:41 PM
In my test I use myself constructed 450V,dc converter.I use SG-3525 chip with ferite core transformer,and tr IRFZ-44N in driver side,in half bridge config.For protectiion I use 50 pcs.of 1N-5408 diodes.Ignition coils is stock,spark plug is NGK without resistor,cables is RG-6 foam coaxial.Mist maker is 36V,placed in engine intake manifold.Others is same.
Hi Alpeko,
Do you mind to show us your project (diagram) using SG3525
since aquapulser RPG4700 its not so "Open Source"...
Best Regards
Nelson
gmeast
Hi all,
I've compiled my videos into to a couple of archives.  One is a DVD Video with a navigation menu and some slide shows all in higher resolution than on YouTube.  The other is a DVD Data Disc with still higher resolution files than on the DVD Video.  1st the Video then the Data Disc.
Yes, I'm so low I intend to sell these ... $14.99 and $19.99 + S&H.  Pieces of evolving history.
Any takers?
Greg
