URGENT! WATER AS FUEL DISCOVERY FOR EVERYONE TO SHARE
Started by gotoluc, June 26, 2008, 06:01:38 PM
gotoluc
Hi everyone,
I have been busy with a job I had to start 2 weeks ago, so I barely have any time to work on the development. However I have been following the topic every day and I can say that today is a good posting day as many of the post are on topic. Great job to everyone involved, keep it up.
I know that some of you would like me to play more the moderator role and delete what is not on topic but I chose not to do that for many reasons. So please continue as is and things will get better as we get busy with development and if someone posts off topic stuff just ignore it instead of wasting your time and energy in argument. However if a post is negative towards anyone or anything please let me know and I will delete it.
I just updated my simple circuit today since as indicated before by Aaron of the Energetic forum, the Capacitor alone is all that is needed, also another user of that forum showed that my circuit still kept the bridge side connected as the cap discharged. With the new change the circuit is working the best so far. Also you can now plug it right in the wall since the switch brakes the bridge from the cap and circuit at discharge.
I made a new video to reflect all the changes to date:
http://www.youtube.com/watch?v=FxnRQ7fkWtE
Please have a look and see if it's good.
Luc
Added link to schematics: http://www.overunity.com/index.php/topic,5024.0.html
ninjadaniel
BAM! we have plasma spark!!
Just made a voltage doubler as seen in the diagram in posts above.  Using 450v 330uf as C1 and 450v 150uf as C2, 1n5408 diodes.  Charge it up to around 350v and BANG, very very nice plasma spark (my dad could hear it from across the street).  I think 1x 12kv microwave diode is not enough to protect the inverter as i just blew a cheapo 150w one.  For future tests i will try 4 of these (2 in series with another 2 to allow 1amp and block 24kv).
A few tips, if your engine has a positive earth/chassis, you will be unable to get any sort of plasma spark without making a custom plug allowing you to put a protection diode to stop the LV going back into the engine,  without this diode you may get a spark or two but more often than not you will end up with a dead short.  However for tests, simply bring the plug away from the engine, run a "ground" wire back to the engine with the diode in it- this will simulate a custom plug.
Another thing, with these voltage doublers, you will find they will charge extremely fast... so keep an eye on your multimeter and dont let them blow up!  I am/was using a 150w inverter which gave me plenty of time to watch the volts go up on the multi.
Shanti
QuoteI would like to commend you on this video and make a note to others that it is indeed a marble and not a foam ball that you are lifting with a water explosion. A marble does have considerable mass and requires REAL power to be lifted. Such video examples proving the proof of concept can only help in our endevour to gain awareness of this process in an effort to further it's development.
First I want to congratulate for a good demonstration of the principle.
But on the other hand I still feel, that people should not become too overexcited too soon. Because simple calculations show, that your 100uf will have an energy stored of about 5J. Let's say the marble jumped 10cm=0.1m (about 4 inches), then from the energy standpoint, this energy should be enough to have lifted 5kg (11lbs) this 10cm up in the air.
But I think what you do is good. First get it running, and then try to optimize the efficiency.
Shiver
To be fair, it was just an aside finding something that would roughly fit to give an idea that there's some kind of work being done.  That alone is a great advance.  Once I have mine built to satisfaction, the first thing I'll be doing is making something to reasonably accurately measure what energy is being made available.  I hope somebody beats me to it, because I won't even be able to start until September  :'(
