URGENT! WATER AS FUEL DISCOVERY FOR EVERYONE TO SHARE
Started by gotoluc, June 26, 2008, 06:01:38 PM
gotoluc
Quote from: whopper1967 on July 17, 2008, 04:15:00 AM
well,i tried to create your circuit again tonight luc,still whenever the rectifier is hooked up to the inverter it trips,when i hooked it to mains circuit breaker tripped.I put the light bulb in between the inverter and rectifier as suggested.When the rectifier isnt hooked up,the inverter runs the light bulb fine,as soon as I hook up the ac to rectifier,it is done.Seems like bad rectifier maybe,what do you think?
Yes, that sounds like your rectifier maybe fried. Get a new one and hook it up just to the cap and nothing else and plug it in the wall. If the cap charges now you know this part of the circuit is fine. Unplug it from the wall and be very careful with the cap and use a light bulb to drain it. Now connect it to the switch and circuit and retest.
Luc
db
Hi K4zep
What if you used the water from the top of an electrolysis cell that had the H and O suspended in the water?
Dave,
alan
Sorry to ask this because I am sure it has been already said before:
how are switches S1 and S2 timed? Alternating or simultaneous?
Scopeshots of the cap during operation in all modes would be great to get some insight.
Thanks Peter L. for also looking into this.
k4zep
Quote from: db on July 17, 2008, 10:29:30 AM
Hi K4zep
Dave,
The best thing I can tell you is build a simple motor or at least a cylinder, put a plug in it and mist with this water and see what happens!  Develop some method of measuring total volume expansion and fire away.
Ben
