Water for fuel - diesel
Started by nightlife, June 30, 2008, 01:48:44 AM
resonanceman
PLAN     B
Assuming  that  the diesel injectors  won't  work   .......  and   we have to find another  way to  control the output .
I still like the diesel .
From  what I understand    the process we are working with the plasma doesn't actually  burn  the water ......it just flashes it into steam .
If  this  is  true  we can use  the  timing of an ignition  spark to  control   how  much  power is  created .
As long  as   we are making  plasma    we are making  more  heat .   I see no reason   that we couldn't   keep  an arc going for  up to  around  90 degrees  of the  stroke .
A diesel  works with higher   compression  and   usually  turns  slower  than a  conventional engine ........so that gives us more  time and pressure to play with .
Of course  we would need  a higher  frequency  inverter   for  sustained  plasma
As I said  .......this is plan B  .........I am still optimistic  about plan A
ramset
All for all of us a car is a big capitol   investment  one that has spoiled us with dependability  running water through our 1500-3500 $ injector pumps is scary  However who says we need the pump  if we are using s1r tech to ignite the water circuit plug etc  all we need is a water delivery system[carb]  fuel injector pumps cost so much because they are very high pressure  were doing a whole dif system
Nightlife have one of your mechs bring a rig up to speed [temp]kill the fuel and put an IV [ water drip] see if she keeps going Im out of town but when I get home I have an old diesel I will try this on  Chet
Thanks Grandma
Yucca
Quote from: nightlife on June 30, 2008, 01:50:16 PM
It seams, after reading the following pdf file, that when the water is introduced to plasma, it is creating a "cold" fog explosion. This means there is no heat and therefore would not need to be preheated to get the results.
http://f1.grp.yahoofs.com/v1/EBFpSJS-sMYpa8Cek1PzGHH5WYgLGp5EbYiB0zypKT-db8__
30ijrUD_Ai48FWCEJ0HNPnXiasFyEo1ipRExiqkMdXwFzKRoHls/Graneau%20experiments.pdf
The Graneau experiments, Oh yes a very interesting read and extremely relevant to this thread, here it is for people without yahoo group login:
http://www.overunity.com/index.php?action=tpmod;dl=get93
resonanceman
Quote from: broli on June 30, 2008, 04:14:53 PM
[fixed link]http://www.youtube.com/watch?v=mSDtCkLxQd8
Good find  on  that video
It is kind of like  what  I was  planning on  doing
a metered  amount of water   put in that thing    would make a  controlled amount  of heat .
That heat will be  injected into  the cylinder    at supersonic  speed
As the air in the  cylinder  mixed with the  plasma   it would expand .........much like if it was burning .
It is nice to know it has been done   before................it is not nice to know that no one knows  anything about it  now .  .
gary
