Water for fuel - diesel
Started by nightlife, June 30, 2008, 01:48:44 AM
ramset
gary it hasn't   that is theory revolving around an anomaly 90 yrs old   no one put this to a car [except S1r]  they put it to metal forming in the 60's   who wants to burn water? where do you make money? NOW  we play NOW we see!!!  something as passive as water puts the little guy on the Map Chet
there is a patent a man has on water steam /gas engine it switches to water at 500 degrees and back to gas below that the only reason I bring it up is in a diesel once it is running we may not even need a plasma plug or we may find the diesel fitted with spark plugs will burn water just like a ICE just add a carb time will tell
Thanks Grandma
resonanceman
Quote from: ramset on June 30, 2008, 04:48:31 PM
All for all of us a car is a big capitol   investment  one that has spoiled us with dependability  running water through our 1500-3500 $ injector pumps is scary  However who says we need the pump  if we are using s1r tech to ignite the water circuit plug etc  all we need is a water delivery system[carb]  fuel injector pumps cost so much because they are very high pressure  were doing a whole dif system
Nightlife have one of your mechs bring a rig up to speed [temp]kill the fuel and put an IV [ water drip] see if she keeps going Im out of town but when I get home I have an old diesel I will try this on  Chet
Chet
I agree .......    I think there are lots of ways to get it done .
I   am still  planning on using  the injectors .     I am sure others  will  be working on other ways
gary
resonanceman
Quote from: broli on June 30, 2008, 04:14:53 PM
[fixed link]http://www.youtube.com/watch?v=mSDtCkLxQd8
Did  anyone else notice that he  only has a spark plug  wire coming out of that thing .........and a blue connector that  I am guessing is for water .
gary
Tinker
Chet
What you say is valid but but would we not be better served by using the existing components where ever we can.
One option to the lubrication issue I can think of can be found here
http://inventors.about.com/library/inventors/blteflon.htm
The question here is can it be mixed with H20 or would it need to be injected from another source, and will it cause a problem during combustion.
P.S. your right about the Detroit diesel's
Be well
Tinker
nightlife
ramset,
QuoteNightlife have one of your mechs bring a rig up to speed [temp]kill the fuel and put an IV [ water drip] see if she keeps going Im out of town but when I get home I have an old diesel I will try this on  Chet
That is a good test to try and I will try that tomorrow with a 6.9 diesel.
