Hubbard coil
Started by EMdevices, July 01, 2008, 05:03:36 PM
giantkiller
Well I don't want to stray to far into no man's land but we were shown small black video transformers as a clue. And then a string of them. Bend them in a circle and we are at where we should've been then. Here, the Hubbard coil and our very attempts.
How many ya got there? 4? 8)
There was so much to investigate at the time and I had alot to learn, then boil it all down to a few operational patterns. We are here. Let's not dig up detail where the pattern is enough to go on. Wise words of Loner's. Otherwise, the California fires appetite pales in comparison with the potential lost time.
To be fair, I am on a course of action to match up with the operational patterns of this technology. The subsets of this Hubbard device have appeared in front of me. Even if it isn't the end zone I cannot give up like many of you, whether you build or watch.. This End Time Addiction is most justified.
--giantkiller. This could go awry if we choose. I choose to stay on track.
khabe
Why not magnets and circuits ? I like some kind of magnetic circuit like "gates" idea. When videos then SM talking about limited time because unit comes too hot and will be self-destroyed.
In years he built and demonstrated there was no high temp Neodymium magnets like today (M,H,SH  etg), was just N28...N35 - normal grade where magnetic properties will be lost forever when temperature exceed 80C degrees, even it was 70C degrees this time if I remember correctly.
khabe
giantkiller
Quote from: giantkiller on July 22, 2008, 04:57:04 PM
Even if it isn't the end zone. I cannot give up like many of you. Whether you build or watch.. This End Time Addiction is most justified.
Even if it isn't the end zone. And like many of you, I cannot give up whether we build or watch.. This End Time Addiction is most justified.
khabe
OK, Respect, but  why to be bullheaded. Im trying to tell you that your "iron" is not good. First  as material choice and second - its ill-proportioned too long compared to magnets and coils. Too big losses.  Wire you using is thick and such kind  insulating is also thick  - in result you have nothing inside of coils/between magnets instead of losses.  Is this iron wire the only possible choice you can find about ferros materials? Seems Micrometals not interesting for you but even wire if to use it must to be bit better stacked and more tightly pressed together. ... even non coated steel is better, common oxide helps against eddy losses as well. Soft iron wire, up to 0,5mm, black thermal oxide  ... Iron-Nickel  0,2mm fire - of course much better ... And cut surfaces need to be absolut perfect!
khabe
PS:
I did play with Hubbard coil somewhere two years ago,  not much results, then saw SM TPU in Overunity ... I lost interest ... but my Hubbart version is still  in my cellar, at least most of parts.
z.monkey
Howdy Khabe,
I have spent a lot of time chasing Hubbard's design.  He built it the way that he did, with the materials that he did for a reason.  Form follows function.  Hubbard's Coil worked then and it will work again.  You TPU guys are always chasing extremes, the Hubbard Coil is pretty boring compared to that.  Its just a current generator, bor...  This current generator is supposed to resonate close to line frequencies, have a large current supply at a relatively low voltage.  Perfect for running your, say, uh, air conditioner, heater, lights, lab bench...  Granted its not "kickin" at 40 Khz and producing 10 inch arcs, its a little more practical.
Don't be dissin' the design...
Blessed Be Brothers...
Goodwill to All, for All is One!
