Hubbard coil
Started by EMdevices, July 01, 2008, 05:03:36 PM
giantkiller
Quote from: z.monkey on July 07, 2008, 01:22:50 PM
Howdy,
So you are saying the initial impulse of energy chases itself around the set of primary coils?  Like an all inductor oscillator, or one of those transformer amplifiers?  It seems like the charge would diminish over time and need to have some maintenance current, but if the thing is able to draw Zero Point Energy then It can use that to maintain the rotating charges and provide output current.  Assuming the current in the primary coils is pulsed DC, it should have an interesting output waveform.
Blessed Be Brothers...
And on they Deyo coil we can not see all the connections, but they look in series like your diagram. And all 3 rings.
--giantkiller.
z.monkey
Howdy Y'all,
The Schumann mechanical resonant frequency of Earth is, or was, 7.8 Hertz.  It is increasing.  I haven't measured it myself but I have read a lot about the natural "biorhythms" of the Earth.  There is quite a lot of natural radio signals generated by the Earth moving through space.  Most of these are in the ELF and VLF bands, really long waves.  The sun, however, is generating higher frequency radio waves and i would not be surprised if it is responsible for "pumping" the TPU and the Hubbard Coils.  The Earth itself is a receiver and the local transmitter is the sun.  It seems like the geometry of the coils would have something to do with the resonant frequency of the Hubbard Coil.  The larger the coils get the lower the frequency, just like mechanical resonance.  So theoretically we could build a Hubbard Coil to be a specific size so that it resonates with some naturally occurring frequency which would boost the output power.
I am firmly convinced that "free" energy exists by design.  It was provided as part of the universe by our benevolent creator.  This is something that has been very carefully hidden from us by our former malefactors.  They did everything in their power to stamp out "free" energy, and used oil as a substitute in order to make themselves rich.  Now Pandora's Box is open and we all know about "free" energy.  Today is a sad day for our former malefactors, they have lost their stranglehold on humanity.  May they die well!
Goodwill to All, for All is One!
aleks
Quote from: z.monkey on July 07, 2008, 03:58:08 PMit is responsible for "pumping" the TPU and the Hubbard Coils.
Things can actually be different with these devices. "Quantum vacuum" patent link to which I've posted above hypothesizes that what is known as the "relic radiation" (microwave radiation) is actually a constant free energy production happening throughout the Universe by interstellar hydrogen atoms. It's not a residue from the "big bang" as established science suggests. It's actually more logical than the "big bang" reasoning which was probably invented only to support "energy conservation" (and there are some contradictions to "big bang" theory exist as far as I've read).
z.monkey
Howdy Y'all,
Here's a new schematic to play with.  I feel like the construction of the cores is essential to the proper operation of this device.  The primary cores in my current Hubbard Coil are built with 1/2" by 8.25" iron plumbing tubes with 1/2" by 10" steel hex machine screws inside them to hold the ends on the mounting plates.  I had to bore out the tubes to get a nice fit with the machine screws.  I feel like this configuration is not adequate to achieve a sufficient magnetization.  The cores should be built from a cluster of laminated soft iron wires with the windings as close to the wires as possible.  The current Hubbard Coil also is configured with the secondary output coil on the outside of the device.  It is a 4" diameter by 8.25" long black iron plumbing pipe.  This configuration has seven primary coils symmetrically aligned inside the primary coil.  Admittedly this was my interpretation of the Hubbard Coil.  I wanted to achieve the same functionality as Hubbard but built with "off the shelf" materials.  This explains the less than satisfactory performance, but that is also the fault of my operational philosophy and the drive electronics.  Based on the new theories presented in this thread my Hubbard Coil and the drive circuits must be completely redesigned.  The design can be simplified drastically compared to trying drive the coil with a radiant capacitor discharge actuated by a relay.  After more study, the original Hubbard Coil was simpler, and that means more rugged, reliable, and cheaper.  These qualities are all desirable.  Eventually we may have to rely on these generators.
mdmiller
The hyperlink below contains an analysis of the Hubbard coil dimensions, wire sizes, windings, and derivation of the probable operational frequencies.  This might be of some help.
http://atl2.netfirms.com/engy/mutch/matrixlaw/hubbard.htm
-duane
