New low voltage electrolysis process from Dr. Linnard Griffin
Started by hartiberlin, July 05, 2008, 02:04:24 PM
hartiberlin
Forwarded from Dr.Linnard Giffin:
Confidential and Proprietary Global Hydrogen Inc
GET READY TO HYDROGEN POWER YOUR CAR?
400 miles = 16 gallons of gasoline at $4.00 per gallon                = $64.00
400 miles =   9kg of hydrogen at $2.47* per kg @ 6cents/ kWh  = $22.23
Next year you are going to upgrade your TV to digital why not up grade your car to hydrogen?
Low cost hydrogen generator.  A newly developed electrolysis process will allow you to run your car on water.
From the lab of a new entry into the craze for green power is a small company called Global Hydrogen Inc.  Located in Bertram Texas Global hydrogen Inc. was founded by Dr. Linnard Griffin in early 2007. Dr. Griffin has announced the discovery of a new low voltage electrolysis process for generation of hydrogen and oxygen. Dr. Griffin has also developed a unique hydrogen generator shown in lab prototype above using this new electrolysis process.
Using propriety electrodes and cell design this process generates hydrogen and oxygen at less than 41.2 kWh per kg of hydrogen. During an interview with Dr. Griffin Dr. Griffin claims that everyone told him that it was impossible to generate hydrogen under theoretical minimum1.23 volts. The generator shown in the photograph above is producing significant hydrogen at room temperature at less than 0.9 volts, almost ? the theoretical limit of 1.23 volts.
Dr. Griffin claims to have evaluated a new electrode material that can boost gas production greater than the proposed industry goal of 50kWh per kg of Hydrogen.
Hydrogen produced by natural gas reforming was until now the best known efficient process of 3.5 kg of Natural gas for each kg of hydrogen. With natural gas marketing for $1.02 a kg the cost of Hydrogen, made with natural gas is $3.57/kg. Using Dr. Griffins process and the industrial standard of 6 cents per kWh a kg of Hydrogen can be produced for more than a dollar less, or $2.47 using the standard Utility grid, just about anywhere.
Looking toward clean energy such as windmill or solar the kWh is predicted to be around 3 cents per kWh or $1.236 per kg of Hydrogen or equivalent to $1.2399 for a gallon of gas.
It is possible to use an in-home system to produce hydrogen at the equivalent about $3.29* cents a gallon gasoline. Lower cost could be done using off peak and super off peak hours to make your hydrogen as low or lower than the industrial power of $2.47 per gallon equivalent.
Submitted by Homer Webb CTO Global Hydrogen
*Lowest known cost method of hydrogen production is natural gas steam reforming @ $3.57 per kg (at 2008 natural gas prices).
GHI?s process of :  $1.24 cent per kg H2 (gas) @ 3c cents per kWh on     Wind, Nuclear, Solar.
  :  $2.47 cent per kg H2 (gas) @ 6c cents per kWh on    Industrial.
  :  $3.29 cent per kg H2 (gas) @ 8c cents per kWh on    Residential Power.
Lab data available on request after NDA.
hartiberlin
johnfarmingdale
hartiberlin wow great work. I have been interested in Electrolysis for a while now and this is great work. I would love to convert a motorcycle.
Thanks again hartiberlin.
hartiberlin
Hmm,
was Dr. Griffin bought out by the oil industry ?
His website is gone.
These were the last press releases I could still find on the web:
This is from 2008:
Global Hydrogen, Inc. Announces Process that will Lower Hydrogen Costs
NewswireToday - /newswire/ - Austin, TX, United States, 07/24/2008 - Low-Voltage, Low-temperature process produces less expensive Hydrogen.
Global Hydrogen, Inc. announces a newly developed, low-voltage, low-temperature, and high-efficiency DC voltage electrolysis generator for producing hydrogen efficiently and inexpensively. Leveraging proprietary electrolyte solution and electrode construction, this system is producing 1 kilogram (kg) of hydrogen per 41.2 kilowatt hour (kWh) with approximately 90% efficiency. The most efficient systems produce the same amount of hydrogen utilizing more energy, usually around 53.4 kWhs. This technology stands poised to revolutionize the hydrogen generation industry and all other industries that relate to hydrogen energy.
The ideal hydrogen production system aims to produce hydrogen for less than $3.00 per kg, or about 6 cents per kWh. Currently, the most efficient systems in use are producing hydrogen at $3.20 per kg, short of the industry’s ideal goal, while the rest of the industry is producing hydrogen for approximately $3.57 per kg. Global Hydrogen’s system produces hydrogen at $2.47 per kilogram.
Consider that 1 kg of hydrogen is equivalent to 1 gallon of gasoline. To travel 400 miles on traditional gasoline, at $4.00 per gallon and 16 gallons to the tank, would cost a consumer $64.00. Using Global Hydrogen’s patent-pending process, you can travel the same 400 miles for $22.23.
Not only does this system produce hydrogen more efficiently than most, but it can efficiently produce hydrogen on any power grid, including residential power grids. With this process, it will soon be within reach of the average consumer to affordably utilize hydrogen power.
The most common hydrogen production technique involves the steam-reformation of fossil fuels, which not only consumes limited natural resources but also contributes to polluting our environment with greenhouse gases as a by-product. The Global Hydrogen process uses water, not fossil fuels, to generate hydrogen. Additionally, NO greenhouse gases are produced in the process.
About Global Hydrogen, Inc.
Global Hydrogen (globalhydrogeninc.com) was founded in 2008 by Dr. Linnard Griffin, an independent inventor who holds several patents related to hydrogen generation, metal reduction, and a novel cooling fluid. The company is driven by a desire to provide less expensive alternative energies to consumers, thereby reducing the world dependency on non-renewable energy resources.
This last one is from 2009:
´Global Hydrogen, Inc. Announces Controllable Hydrogen Generation Process
Abstract:
Global Hydrogen, Inc. announces a newly developed aluminum nano-nickel hydrogen generator that can be controlled by flipping a switch, producing on-demand hydrogen.
Leander, TX | Posted on April 23rd, 2009
The simple system is self-contained and portable. While the system is scalable, the first production unit has been designed to produce 4 Kg, or 44,000 liters, of hydrogen at 0.5 Kg per day. The unit is 3 cubic feet in size.
This system is more efficient, less expensive, smaller and lighter than comparable systems. The generator normally operates at ambient temperature, but it will produce up to three times the hydrogen at a low temperature of 90 degrees Fahrenheit.
Dr. Linnard Griffin, inventor and founder of Global Hydrogen, Inc., states that this new system is designed as an ideal replacement for bulky storage batteries and dangerous high pressure hydrogen storage tanks used in emergency power backup systems such as cell phone towers and other remote applications. The system is also ideal for use in the automotive industry.
To view a video demonstrating the process, refer to the Supporting Documents page of the company Website, linked below.
For more information, please click here
Contacts:
Dr. Linnard Griffin
512-818-3309
linnard.griffin
