S1r PDF coil description and discussion !!!!
Started by xbox hacker, July 08, 2008, 03:20:41 PM
bumfuzzled
Oh boy he showed how to dismantle a BS coil!!!
atlasman
xbox, if you already have the parts, could you watch the video and rebuild your s1r coil to his exact specs here since you can see the vid, and let us all know if it truelly is a BS crapblower or if the thing really does "shoot lightning" when you hook it up.
p.s. what im really trying to do is get someone to try this now that we can see the build and disassembly array without me haveing to do it, because my faith in it is pretty close to "0" ;)
atlasman
p.s.s.  what i really cant understand is why would a guy take his time to build something like that and put posts on the net and make video's and post them on his weekend off, if there was "nothing to it".  I mean he prolly has several hours into doing all this.  I know i like to kid around, but i have got much better things to do than just "waste time" ,,,, for WHAT?
so MAYBE there is something to this, so i raise my faith level to "1 or 2" now.
tinu
Quote from: atlasman on July 15, 2008, 12:26:25 AM
atlasman
Faith level? Please read my opinion too.
That?s the name of the game in FE/OU: bring more people by any means, wash their brains, make them believe and later they?ll gladly take their time, resources and money, even in small amounts it counts because what?s most importantly is: make one bring many and make hordes growing larger. One nut is enough to bring hundreds?
Many will probably get upset on me because of the above...
What actually one chooses to believe it is not of my concern. I?m just upset because the mud blocks the light, if any out there. Taking an unproved claim and amplifying the noise around it doesn?t help at all. Some would call it manipulation. An ordinary one. How on Earth is that possible?!
Have a nice day,
Tinu
Bruce_TPU
Hello All,
I know that most of you have given up on this coil.  But I saw something interesting in it, and conferenced with some other folks from TPU land, about this coil.
We are going to build the coil and test it.  Not with the plug, etc, but with HV pulses.
The coil is unique in several ways.  I will list some of those, and you can feel free to research each if you care too.  As you know, in TPU land we have been studying coils and their interactions for a very, very long time.
1.  Nail=iron core   (Shows someone has a clue who built the transformer)
2.  coils set up to interact with one another and them selves (90 degree rule)
3.  Uninsulated wire over the iron is wrapped like a "magnetic flux accelerator"  See link below, translated, 1/3 of the way down the page:
http://translate.google.com/translate?u=http%3A%2F%2Fweb.archive.org%2Fweb%2F20060818094519%2Fhome.arcor.de%2Ffreie.energie%2Fmagnetbeschleuniger%2Fmagnetbeschleuniger.htm&hl=en&ie=UTF8&sl=de&tl=en
4.  The coil has a LV steady bias, with HV pulse on top.  (Think SM, AC riding on DC)
5.  Coil pulsed with extremely HV pulses
6.  Many other things the guys pointed out, too many to list.
BUT having said all of that, it will be bench tested and that will determine what it does.  We will be winding it according to the .pdf, not the drawing by third party's.  We'll post our results, probably by the end of next week.  If it does not work, we will use his principles, change a few things and make it work!
We need a unique HV pulse transformer for our own work, and this is why we will be testing this.  Also, if it helps you guys out, that would be great as well.   ;)
Cheers,
Bruce
atlasman
You the man bruce!  Apparently your smart enough to do all what you say you will, or you wouldnt have said it all  ;D.
Im looking forward to seeing the final "WORKING" product.
atlasman
