S1r PDF coil description and discussion !!!!
Started by xbox hacker, July 08, 2008, 03:20:41 PM
Bruce_TPU
Hi Forest,
Tesla found that helically wound coils were best to "capture, detect" RE was best.  There are many ways a helical coil can be formed.  In the shape of a toroid or solenoid or other shapes.
Cheers,
Bruce.
c0mster
Quote from: Bruce_TPU on July 20, 2008, 03:38:50 PM
Has anyone put a pickup coil near the tip of the spark, and scoped across it?  Has anyone scoped the HV output?  Just wondering.  ;)
Yup.
vrand
Quote from: c0mster on July 23, 2008, 10:45:53 AM
Yup.
Hi,
Can you post photos of the scope shots?
Is it a single discharge event or a ringing oscillation?
Regards,
Michael Randall
Dmoney
This is several videos showing waters power exploding.  Blows several things apart in earlier videos.
http://www.youtube.com/watch?v=RiRqrQC7DJ8&feature=related
Darren
